Results 1 to 8 of 8
    Default battery seems to increase slightly by itself
    Notice it has not been on the charger at all but it seems to spike up a little here and there...happens all the time...wondering if yours does it too...thought it was interesting......plus my battery life is awesome
    Attached Thumbnails Attached Thumbnails battery seems to increase slightly by itself-screenshot_2012-02-19-21-35-19.jpg   battery seems to increase slightly by itself-screenshot_2012-02-19-21-35-10.jpg
  2. #2
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    Default
    Are you running fully stocked? Unlocked rooted with a rom flashed will increase your battery life further.
    dropped from LiquidNexus via TapaTalk
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  3. #3
    bberrynewbie84's Avatar
    Galaxy nexus!
    Posts
    Global Posts
    520 Global Posts
    ROM
    stock 2.3.4
    Default
    My battery was good on the kang from but it sucks on the leaked 4.0.4 rom
    Default Re: battery seems to increase slightly by itself
    No Im straight stock.....Im just talking about my phone seemingly gaining charge without being charged. I dont need better battery life I got over 13 hours with nearly 4 1/2 hours of screen on time. I have just noticed with the above screen cap and others that my phone will drop to a certain point and then if I dont use it for a little the battery actually increases without being charged.
  5. #5
    turdbogls's Avatar
    Posts
    Global Posts
    364 Global Posts
    ROM
    changes all the time
    I have notice this as well. happens whenever the phone is off the charger for a while. not sure why it is doing this, but it is obviously a bug in the battery reporting or something....unless google has finally made self regenerating phones
    Quote Originally Posted by turdbogls View Post
    I have seen my beautiful battery widget be at 10% and then I dont use the phone for awhile and I come back and itsat 13%......just thought it was weird. Wish my battery was regenerative....that would be awesome. Of course if that technology was invented to a competent degree it would probably never see the light of day. To much money to be made in inefficient power usage.
  7. #7
    xiaosong's Avatar
    Posts
    Global Posts
    95 Global Posts
    I noticed that yesterday too after I had played Sentinel 3 on my phone.
    Maybe is has something to do with a higher battery temp when the phone is under load and when it cools down, it recalibrates the battery usage or maybe android calculates battery usage based on load and it re-adjusted when you lessen the load on the battery.
  8. #8
    that is def interesting. it probably readjust based on use??
    hey your battery life looks excellent, is this your typical battery life?
