Re: Tune-In Radio Problems
I agree. I never listen to podcasts really at all. But the Radio Stations I have listened to on TuneIn havent given me any cut out problems. I use it almost everyday at the Gym. And thats letting it stream over 3G. More then likely the source.
I have the same problem while listening to TuneIn podcasts on my gnex. Within 30 seconds of the screen turning off, the podcast will stop playing, and start re-filling the buffer once the screen is turned on.
The only workaround I have determined is to keep the screen from shutting off, either by changing the phone settings, or using the app in "car mode," which does not turn the screen off.
Other than a few inconveniences, I love the app!
This is a known bug with GNEX that wi-fi shuts off when the screen turns off. Happens with Tune In, Slacker, everything, except oddly enough....Google Music.
There are many threads on Google support site about this. I encourage everyone to add your own experience as well.
Very frustrating indeed......
Good news! I emailed TuneIn support (android@tunein.com) and they sent me a download link for v6.0 Beta... it seems to have solved most of my issues, including the screen timeout/buffer issue!
Yeah, I have that problem and have a question. I mostly listen to talk radio, sports and political and can't turn it off. Also, I don't want to record anything. Only live broadcasts. Any ideas?
I use tune in to listen to a few music stations. I have the same issue. I found it happens only when the screen is off. Select in tune ins options to disable screen lock. It uses a ton of battery because the screen is on while the app is running but the stream will actually buffer and not stall. Its am app issue happens on all the stations I've tried.
Tune-in stopped working for me recently. It starts buffering but never gets there. Moreover, I tried uninstalling it, to reinstall, to see if that would help, and it won't uninstall. My phone is a HTC OneX. I use it just to listen to live radion, mostly Dutch Classic FM. Classic FM has an app, which I downloaded, and, oddly, the same thing happens. It buffers forever and never plays. No problem with other radio apps. Any ideas please?
Hi All, ignore my last remark, I've now got the Dutch Classic FM app to work . . but any suggestions about the Tune-in problem would be appreciated
Get the Pocket Casts app. It is so far superior to Tunein Radio for listening to podcasts.
