Results 1 to 11 of 11
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Default GSM auto (PRL) - Can the GNex Connect to a GSM Network or Not?
    When I go to Phone Information after dialing *#*#4636#*#*, Set preferred network says GSM/CDMA auto (PRL), I can make and receive phone calls as well as use data. GSM service says In Service.
    If I go into settings>more>mobile networks, the Preferred network mode says LTE/CDMA.
    When I go into settings>about phone>status, the network is Verizon Wireless, not roaming and Mobile network state is Connected.
    ___________________________________________________________________________________
    When I set my preferred network type to GSM auto (PRL), I can make and receive phone calls as well as use data. GSM service says In service.
    If I go into settings>more>mobile networks, the Preferred network mode says GSM/WCDMA.
    When I set my preferred network to GSM only, I can't make or receive calls or use data. GSM service says In service.
    If I go into settings>more>mobile networks, the Preferred network mode says GSM only.
    When I go into settings>about phone>status, the network is Verizon Wireless, not roaming but Mobile network state says Disconnected.
    ____________________________________________________________________________________
    When I set my preferred network to WCDMA only, I can't make or receive calls or use data. GSM service says Emergency calls only.
    When I go into settings>about phone>status, the network says Searching for Service, not roaming but Mobile network state says Disconnected.
    _____________________________________________________________________________________
    So what does this all mean? Can the GNex connect to a GSM network or not?
  2. Thread Author  Thread Author    #2
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Default Re: GSM auto (PRL) - Can the GNex Connect to a GSM Network or Not
    Anyone know why I can make phone calls when I have it set to GSM auto (PRL)? Is it because of the PRL (Preferred Roaming List)? I definitely can't make them in GSM only or WCDMA only.
  3. #3
    No, it does not work on GSM networks. It physically doesn't have the radios to do so.
    Don't look to much into the fact that it says network mode is GSM/WCDMA.
    LG Nexus 4 // T-Mobile
    Thanked by:
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Quote Originally Posted by martonikaj View Post
    Okay, can you help me understand the GNex hardware?
    There are 2 data chips - LTE and EVDO - Samsung CMC221 and Via Telecom CBP7.1. What piece of hardware is involved in voice calls?
  5. #5
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,137 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    Quote Originally Posted by GNex Girl View Post
    The EVDO chipset. Verizon voice calls use the 1xRTT network which is considered a 2G network. The EVDO chipset also handles 3G data. Having separate LTE and EVDO radios is what allows simultaneous LTE and voice on the Galaxy Nexus.
    Sent using Tapatalk
    Thanked by:
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    So the Via Telecom CBP7.1 chip can't handle a voice call on a GSM network and therefore, there is no way the LTE GNex can be used on a GSM network?
  7. #7
    Posts
    Global Posts
    10,137 Global Posts
    ROM
    Default
    Not aware of any GSM functionality in the device. If you are inclined to dig into it further you could search for the FCC submission that Samsung made, which provides details on the radios and antennas in the Nexus. Also, take a look at the review on Anandtech. They take a more detailed technical approach to their phone reviews.
    Sent using Tapatalk
    Thanked by:
  8. Thread Author  Thread Author    #8
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Quote Originally Posted by NotJustAPhone View Post
    Well here it is, but I have no idea what I am looking at.
  9. #9
    Posts
    Global Posts
    10,137 Global Posts
    ROM
    Default
    This should be more approachable and answer your questions. They dig in deeper than the typical review.
    Sent using Tapatalk
  10. Thread Author  Thread Author    #10
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Sent using Tapatalk
    This page says that the LTE chip uses FCI FC7851:
    What is the FCI FC7851? Is it capable of HSPA+?
  11. #11
    h
    Even if it is true I don't have any idea how we can use it.
