1. winste's Avatar
    I really want to keep this phone. I got it yesterday. At home my signal is usually around -107db and 30 asu.
    My X is usually -87db or better.
    So at home I keep wifi on. I use an N router.
    Not only does this phone lose cell signals but also loses wifi signals.
    I don't mind not having great phone service. My cell calls are daytime mostly . But I want consistent data. And if can't get consistent wifi or 4g, I will probably return.
    I'm a bit of a noob on rooting etc but probably will just to see if I can better radio performance.
    I just wanted to see if anybody had better wifi performance on 4.0.4.
    Thanks
    03-03-2012 08:14 PM
  2. ejaymd11's Avatar
    My phone works perfectly on my N and G router.
    03-03-2012 08:18 PM
  3. MattMJB0188's Avatar
    I noticed I can be 5 feet away from my router and it won't report a full wifi signal. It seems that the overall signal is a little low. Where I should get full signal I get around 2-3 bars. Then again, calls are fine and so is data speeds. I mean who cares what the signal bar says as long as the device is working as it should - which it does.
    03-03-2012 08:21 PM
  4. winste's Avatar
    I wouldn't care what the bars say either if it worked. But when I have no bars, I have no service. Data stops and it tries to kick back over to 4G. And then detects a faint wifi signal and tries to kick back over to that. This results in data service at all.
    If the cell signal drops below -110, I can't receive or make calls. The radios on mine are just horrible.
    03-03-2012 08:29 PM
  5. SSHGuru's Avatar
    Yeah in my bathroom (yeah and I NEVER drop it in the toilet) I get a terrible signal. Not too far from my wi-fi router and sometimes I have to hold the phone over my head to get my words with friends move to go.
    I hope 4.04 fixes this.
    03-03-2012 08:43 PM
  6. CallerHoller's Avatar
    I didn't notice any change in wifi from 4.0.2 to 4.0.4
    I am running IMM30B and the difference between radios is very noticeable.
    I tried Tranquility Ice v7r for a couple o weeks. The radios were a deal breaker. I ran back to IMM30B. Somehow I thought v7r had the 4.0.4 radios.
    03-04-2012 08:25 AM
  7. axne1's Avatar
    Franco's Kernel Helps a TON!
    03-04-2012 10:08 AM
  8. axne1's Avatar
    Also running 4.0.4
    03-04-2012 10:09 AM
