1. biggbrother2's Avatar
    Under Settings>Data Usage.. under Mobile it is saying I used about 3.70 GB for my current cycle Feb 16- Mar 15. However, the MyVerizon app is indicating 2.42 GB used for my current cycle.
    I'm inclined to believe the MyVerizon app, since it's direct from the carrier. But why would the discrepancy be so large? I understand the disclaimer below the data says "As measured by your phone...".
    Anyone else seeing a discrepancy or is your data tracking spot on?
    03-14-2012 08:28 AM
  2. TabGuy's Avatar
    Unlimited here. Never look at the numbers.
    03-14-2012 09:00 AM
  3. biggbrother2's Avatar
    Not unlimited LTE data speeds. You will get throttled after a certain point, so the numbers are still relevant to "unlimited" accounts.
    03-14-2012 09:02 AM
  4. DaRkL3AD3R's Avatar
    I'm unlimited as well but I find this to be a great little tool.
    As far as there being any discrepancies, well I really don't see how or why there would be. I have no clue on this one lol
    From an unlimited standpoint we're speaking on behalf of people not caring about going over any supposed thresholds from a billing standpoint. If we get throttled its whatever. If we go over a set tier limit and have to pay extra, then it matters.
    03-14-2012 09:03 AM
  5. Poseign's Avatar
    Are you looking at just your 3g/4g data or are you looking at 3/4g and wifi combined? over a gig of difference I am inclined to say that you are looking at your TOTAL data usage number and not just 3g/4g, or maybe your data usage thresholds you have set on oyur phone differs from your billing cycle dates, that could be a factor as well.
    03-14-2012 10:10 AM
  6. imnotajedi's Avatar
    I did not realized you can check WiFi usage. Damn I am just over 5GBs on WiFi and just under 1.5GBs on data based on my phone's info. Good thing for WiFi.
    Poseign likes this.
    03-14-2012 10:56 AM
  7. ConTejas's Avatar
    Seriously. I didn't realize you could check WiFi either. In a month I used only 316MBs data and a bit over 5GBs WiFi. 99% streaming Pandora at work for 10+ hrs a day haha. Also, Verizon throttles us Unlimited users? Not that I'd notice...
    03-14-2012 11:59 AM
  8. biggbrother2's Avatar
    I set the cycle in ICS to the exact dates in MyVerizon app - 2/14-3/15, and I don't believe there is a combined data usage amount. It's either Mobile or WiFi.
    What's odd is that in the list of apps usage, Netflix is not listed. I know Netflix must be one of my biggest data hogs. In fact, I went to the gym today and streamed a show and ICS says my usage for today so far was 114MB, yet Netflix is not even on the list.
    03-14-2012 01:24 PM
  9. dubge's Avatar
    when did verizon start to throttle?
    willlayb likes this.
    03-14-2012 05:32 PM
  10. idle90's Avatar
    I had the same issue here as well. I set the dates to match the my Verizon app and I had over a GB difference with less showing on the Verizon app. I didn't have internet for a month so I know wifi didn't play a role.......
    03-14-2012 08:05 PM
  11. JoeNM84's Avatar
    I noticed awhile back that Netflix doesn't get added into the data usage on the phone. Kind of makes it useless for anyone that uses Netflix regularly.
    And has anyone ever heard of people getting throttled on their unlimited plans with Verizon? I only ever see AT&T and T-Mobile users complaining about that. And I thought Verizon actually specifically said that they won't throttle people on LTE, which makes sense since there really aren't that many people on it yet(5%ish).
    03-14-2012 09:48 PM
  12. Mellimel22's Avatar
    haha that's why Im glad I'm with sprint TRUE UNLIMITED
    Sent from my Nexus S 4G using Tapatalk
    03-14-2012 10:01 PM
  13. moosc's Avatar
    Guess u haven't seen the tos stating high use devices can b throttled or even terminated on sprint have u. Of course this for folks that feel they need to connect every device at home and do 100gb of data. No carrier is good sorry
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
    03-14-2012 10:05 PM
  14. whitecomet's Avatar
    big red does not do throttleing as in traditional throttling after a amount. what it does is if you are in teh top 5% and the network is being taxed it will slow you down so the user with less usage is not being slowed down and once you are in a rea that is not being overlaoded you are back to full speed it is optimiisation not thottleing.
    03-14-2012 10:10 PM
  15. diesteldorf's Avatar
    And I don't believe 4G devices are even included for the optimization. I think it only includes 3g devices, but I'll need to look at the terms on vzw.com to be sure.
    Yup, if you have an unlimited plan, and, presumably, a Galaxy Nexus, you can forget about optimization for now anyway.
    http://support.verizonwireless.com/i...isclosure.html
    Will I be affected by Network Optimization?
    Only a small percent of customers will be affected. To be affected, you must be:
    A data customer on an unlimited data plan;
    Have a 3G Verizon Wireless device (if you have a 4G LTE device you will not be impacted); and
    Among the top 5% of data users in a given month.
    Then, you will only be affected:
    When you are on the 3G network; and
    When you are connected to a congested cell site.
    So, there isn't any reason to switch to Sprint just yet.....
    03-14-2012 10:29 PM
  16. davidsnoodles's Avatar
    From what I read from Verizon's website, they don't throttle data speeds if you use a lot (for unlimited data users, say). The only time they throttle data usage is if a tower is congested with data, and it will only temporarily throttle the data until the congestion clears up or if the user moves to a location that's served by another tower.
    03-15-2012 12:56 AM
  17. Droid800's Avatar
    Is the 'month' on your phone set to the correct dates? The data usage app chooses its own dates, so it may not match up to your billing cycle.
    03-15-2012 02:06 AM
  18. Droid800's Avatar
    Verizon doesn't throttle LTE.
    03-15-2012 02:07 AM
  19. PhoenixMike's Avatar
    This is what I remember reading.
    03-15-2012 09:10 AM
  20. Mellimel22's Avatar
    And I clearly read the tos of sprint and it said it will only slow u down if they feel u are using the tethering without getting the plan for the phone repeat I repeat they will NOT throttle u especially if u are using 4g wimax(which isn't all that bad for UNLIMITED) lol
    03-19-2012 07:57 PM
