- 03-24-2012, 02:05 PM
Thread Author #1
NFC problems- tagstand.com
Having a few issues and need advice.
Bought some tags from tagstand a few months ago.
They were not reporting data correctly so the company had to order new ones for me.
They threw in extras for my troubles.
However, every tag they gave me, regardless of type is always reporting an NDEF error and that it's not NDEF compatable or formatable.
I contacted the company demanding money back, but since they teamed up with the developer of the app NFC task Launcher, there is no format option in the app. - 03-24-2012, 04:06 PM #2
Re: NFC problems- tagstand.com
I have read that there is a bug on ICS 4.0.0 - 4.0.2 that will not allow you to format NDEF.
To get around this you have to order your tags already formatted or install a ROM that is based on 4.0.3 or above (bug was fixed in 4.0.3)
P.S.
Tagstand.com will Pre-format tags, it is a few cents extra.Last edited by bakerbert; 03-24-2012 at 04:14 PM.
Sent Via..Raven from Kings Landing
BB Storm 1 > Samsung Droid Charge > Samsung Galaxy Nexus > Samsung Galaxy Note II - 03-24-2012, 08:15 PM #3
- 03-24-2012, 08:20 PM
Thread Author #4
They forgot to pre format the tags so I had to download a competitors app at their recommendation to write a text file that would then format the card and allow me to write data using tagstand app
Sent from the most overhyped phone since the Iphone 4s.... - 03-24-2012, 08:21 PM #5
- 04-05-2012, 08:28 PM #6
- 04-06-2012, 07:13 AM
Thread Author #7
Thanks gang.
Tagstand sent me a ton more tags (I think I lost some LOL) and they sent me a box of cookies too!
Tags are working great.
They refunded my money and sent me stuff which I offered to pay for. Excellent CS...happy with them after the frustration.
I do see a difference too since the new tags came. The first batch you had to be exactly on top of it to get it to read the tag correctly. The new ones seem to have a stronger connection. - 04-06-2012, 08:27 PM #8
Reply
