04-07-2012 12:42 AM
211 ... 23456 ...
tools
  1. NoYankees44's Avatar
    Not rtrying to start an argument here because I know that this subject is very subjective to area, but my rezound has never once lost 4g while in a 4g area. In doors out doors or otherwise. I even spend a lot of time in a shop under my colleges concrete stadium and never lost it down there.
    Once again not trying to start a phone vs phone war, just adding to the mix sense the rezound was one of the phones tested and compared.
    04-02-2012 10:14 AM
  2. Droid800's Avatar
    So have a lot of people. Generally you have to go through several replacement devices before they let you go to another phone.
    An opinion yes but with a lot of truth behind it. The iPhone is well known to be a mediocre phone at best wen it comes to signal
    Last part used to be true. Newer iPhones use qualcomm radios, however, so its not an issue.
    04-02-2012 12:05 PM
  3. bplewis24's Avatar
    Uh, you do know that on your list, the only phone that shows your actual 4G dBm on the Status screen is the Nexus, right? All of the other ones are showing you dBm for 3G or 1x.
    I find it hard to believe that the thread is this long, and the OP has this many "likes" and "thanks", and people are glossing over the FACT that all of the phones in the graph are showing 3G signal strength while the Nexus is showing 4G signal strength.
    Not only that, but the Anandtech article showed a Bionic and Nexus side by side with the logcat displaying the Bionic's actual 4G signal strength (which is the ONLY way to see it's 4G signal strength)...which matched the Nexus.
    The OP has done a great job of displaying this information and doing some basic testing, but the information is in error.
    Does anybody have a real world example of where the Galaxy Nexus exceeds a Moto phone in terms of dropping calls?
    Not me, because I owned both phones and neither one dropped phone calls, although the Bionic did lose it's 4G connection slightly more. But I believe that was due to the network and not the phone. It was still pretty new to Sacramento at the time.
    Brandon
    jroc and ConTejas like this.
    04-02-2012 12:30 PM
  4. Johnly's Avatar
    I owned a Bionic as well, and that did drop calls. That was the reason I ditched it.
    04-02-2012 01:29 PM
  5. ultravisitor's Avatar
    Ok, let's get real. I was trained in science. A degree in computer science from UCLA. The test shown in the first post here is interesting. However, that's all it is. It only shows various tests over a short period from one guys house. Not much scientific about that. We don't know anything about the terrain, the cell tower, the location. The same tests performed a mile away may have been completely different. This was not anything near scientific in any way, shape or form.
    The only solution is to get down off the high horse, no matter the color of your horse, and realize that your point of view only represents your perception. Others have a different perception that you'll never be able to change.
    Exactly.
    04-02-2012 01:37 PM
  6. Johnly's Avatar
    Exactly.
    And there you have it, the Galaxy's serious flaw is not dropping calls.
    I give VZWrocks credit though, he spent time getting this put together; however, the numbers aren't valid. The test needs to be broadened with a proper control, and there isn't one...add that, and you have a believer here...
    dmmarck likes this.
    04-02-2012 01:44 PM
  7. Dreamliner330's Avatar
    ^I figured you'd make a re-appearance.
    If someone takes a measurement of the signal in the same location multiple times, seems pretty scientific to me.
    04-02-2012 01:52 PM
  8. dcastillo's Avatar
    its a good experiment, but not scientific....
    Way to many variables...
    the order that the phones were lined up alone could affect the signals...
    only having one of each phone is an issue considering how sensitive the radio circuitry is, even identical phoens will not have the same signal strength, you would need a larger sample...
    Im assuming he had to hold/touch the phone to view the reading...
    His body alone affects the signal reception...
    even rotating the phone will affect its reception strength
    Its a cool experiment, and its hard to deny the Nexus does have signal issues based on tons of user feedback... but the experiment isnt extremely scientific
    04-02-2012 02:58 PM
  9. bplewis24's Avatar
    Except that is entirely unscientific to compare Apples (3G signal) to Oranges (4G) signal. The entire experiment is invalid unfortunately.
    Brandon
    jroc likes this.
    04-02-2012 03:04 PM
  10. habanophile's Avatar
    I will admit that there may be an inherent flaw in the device, but it has not affected me in any way so far. Cool thread.
    YourMobileGuru likes this.
    04-02-2012 03:13 PM
  11. rbess1965's Avatar
    The test may not be scientific but the community sentiment on these forums pretty much tells all. Look at the posts on the Nexus. Look at the problems being posted. Then go look at the posts on the Maxx. The sentiment is so obvious. Maxx owners are way more happy with their purchases. It's not in any way scientific, nor does it have to be to the open eye. How many posts do you see on the Nexus that are titled Lack of Drama ?
    Check it out and that’s exactly what you see. People can see the contrasting opinions scientific or otherwise. If Nexus owners were that happy why is it I only see a few people defending it from other owners of it saying there's a problem? Face it, there is one. I'm glad that yours is fine but don't try to sell everyone else on a phone that clearly has more than minor issues for everyone else.
    YourMobileGuru and jroc like this.
    04-02-2012 04:24 PM
  12. dmmarck's Avatar
    The test may not be scientific but the community sentiment on these forums pretty much tells all. Look at the posts on the Nexus. Look at the problems being posted. Then go look at the posts on the Maxx. The sentiment is so obvious. Maxx owners are way more happy with their purchases. It's not in anyway scientific, nor does it have to be to the open eye. How many posts do you see on the Nexus that are titled "No Drama phone"? Go to the Maxx forum and thats exactly what you see and people are not crazy they can see the differences. If Nexus owners were that happy why is it I only see a few people defending it from other owners of it saying there's a problem? Face it, there is one. I'm glad that yours is fine but don't try to sell everyone else on a phone that clearly has more than minor issues for everyone else.
    Trying to glean anything realistic and measureabe from the state of nature that is a messageboard is beyond rational and logical comprehension.
    Johnly likes this.
    04-02-2012 04:51 PM
  13. Dreamliner330's Avatar
    So, let's test each phone without touching it in a perfectly scientific clean room with ample amounts of room away from any other radio source to accurately test measure results? Yeah that seems completely realistic as everyday use.
    I seem to remember a certain company saying not to hold your phone in order to get signal...
    The ability to maintain a voice connection is more important than data.
    When I had my Nexus S I remember people saying that a new radio update would fix all of the call dropped problems. It never did and I'm not willing to play that game again.
    04-02-2012 05:22 PM
  14. rbess1965's Avatar
    Fair enough but we have to gather our info somewhere. Those of us who are simply trying to purchase a decent device with our hard earned money are just trying to make informed decisions. Hell the sales people know less about the phones they are selling than the users on these forums. As a consumer I'm just trying to combine what venders say, what you say and what reviewers say to help me make that decision. Why else would we be on here. Thanks for your well thought out advise though and I appreciate you making me feel stupid for considering the opinions of people just like yourself on this forum. I'll try to take it all with a grain of salt from now on. I can tell you this however, the things I've read on here steered me clear of the Nexus and put me in a Razr and for that I'm thankful to the rest of you.
    Cheers!
    04-02-2012 05:22 PM
  15. dmmarck's Avatar
    No worries, I know what you're saying.
    04-02-2012 05:24 PM
  16. ElectroM's Avatar
    Has anyone on here with poor signal flashed the radio and firmware themselves? Not just using the OTA? I did that long ago and it seemed to be better after I completely flashed everything, boot.img, radios, software, everything. You need an unlocked bootloader, but you would be flashing files downloaded from google.
    I have flashed the firmware and radios on mine. I have also tried GummyNex and the Kang 4.04 release. So far the Kang 4.04 is the best, but nothing really improves the signal issue. I still have very poor data connections and I still drop calls, and I am in a very good 4g area. I am convinced this is a hardware problem. I am on my 5th GNex and they all had problems. I don't think it will be fixed by firmware, and that is why there are delays in releasing it. I do know I will no longer buy Samsung products if this is not fixed. I was in Best Buy last Saturday looking for a new laptop, and the salesman wanted to show me a Samsung laptop. I told him no way I would buy a Samsung. Their laptops may be good, but I won't buy one.
    04-02-2012 05:26 PM
  17. thebignewt's Avatar
    My background is science. My quesion to those who say that the OP's "experiment" isn't valid is this: How do you explain his data? (this doesn't qualify as an experiment, nor did he profess it to be one). My second question is: Do you regard his data as showing a significant difference between the signal strenths of the 6 phones? My take is that there is a difference in signal strenth where he lives, a significant difference. I would be loath to attribute it to his hand touching the phone, the orientation of the phone, the fact that 6 phones were operating simultanously as someone suggested.
    04-02-2012 05:32 PM
  18. TabGuy's Avatar
    It may seem scientific to you but it's not.
    If I look out the window 100 times between 9pm and 4am I might conclude from that set of observations that sun never shines where I live. How many times a sample is taken has little to do whether it's scientific or not.
    04-02-2012 05:40 PM
  19. TabGuy's Avatar
    The community here is not a random sampling of the full data set of all Nexus phones. Not even close. In fact, it's a sampling skewed to represent those that complain the most about a given device. Therefore, it can't even begin to "tell all."
    Just because 100 people come here and make a post about something not working for them is not a projection about the large number of phones sold. And, in fact, for everyone saying something doesn't work there is often a similar number that say theirs does work. Followed by a punishing post by the complainers telling the satisfied group to butt out. This type of punishing behavior tends to quiet those that are satisfied so the resulting posts tend to be overwhelmingly in favor the aggressive complainers.
    smcd5213 likes this.
    04-02-2012 05:46 PM
  20. tony bag o donuts's Avatar
    same could be said of those who have functional devices.
    many times people have responded to those having problems that it's the user and they should get an iphone or a bb that is more there speed.
    It goes both ways.
    04-02-2012 05:51 PM
  21. Dreamliner330's Avatar
    But if you place 5 reflective balls outside your window and observe that the one on the left is constantly less shiny, you will accurately conclude that it is duller than the rest.
    The specific number is not important in terms of signal strength, the relationship to the other phones is.
    04-02-2012 05:51 PM
  22. TabGuy's Avatar
    This is a very good question. The answer is that we don't need to explain the data, the one taking the experiment does. Also, it's entirely possible that the Nexus does have the problems described. It's just that the example shown doesn't really say much.
    It's just as possible that if there is a software bug it could be in the the software that measures the signal strength on the phone itself. Maybe the Motorola phone is presenting numbers that make it look better. Didn't the iPhone 4 have a largely publicized "bug" when it first came out over inflating the signal strength?
    There is no proven standard in this unscientific example set of arbitrary observations.
    04-02-2012 05:57 PM
  23. TabGuy's Avatar
    It goes both ways.
    You are absolutely right. And, that's exactly why no conclusions can be made by a bunch of noisy tech forum participants.
    tony bag o donuts likes this.
    04-02-2012 05:59 PM
  24. TabGuy's Avatar
    The example you give is a good one because I can observe directly the reflection of the balls. The one that was shown by the OP isn't the same dataset because the signal strength can't be observed directly it is being reported to the experimenter via software interface. That software is different on each phone.
    04-02-2012 06:02 PM
  25. anthony2558's Avatar
    10 pages of comments to relay that the signal on the nexus sucks. Good work from the OP. There will always be naysayers, because their stuck with the nexus and will be consistently looking for something to fix its poor reception. Its a pretty phone tho.
    via RAZR Maxx
    naiveshopper likes this.
    04-02-2012 06:08 PM
211 ... 23456 ...
