Wow this thread sure has spurred on a lot of good discussion which was the intent. I?m going to address some of your points but not as direct quotes since there has been so much discussion and some people are saying the same things.
* First of all I challenge someone to find the word scientific in the original post. You won?t because I didn?t. I too have had research training (in my case social science but the principles are the same) so I am well aware that this is not 100% scientific. But I take issue with those who say it has no validity whatsoever.
* In an ideal world I would have had more than one device, measured in more than one place, by someone else (double blind study), in a lab where conditions could be controlled, but that?s not practical in the real world. I used as many scientific controls as I could given the circumstances.
* Don?t like my numbers present your own but you need to use similar or better controls. But if you don?t have one or more of the same devices that I do all running stock firmware (meaning not rooted, no updated radios, custom roms, etc.) then it is an invalid comparison to mine. Other than an unlocked bootloader my device is 100% stock.
* As for my own bias, honestly I was completely blown away by how much of a difference there was consistently. I had done some measurements before, but in the back of my head I told myself they must be isolated incidents and that the data would even out to something closer to the others (it was obvious that it was poor but it couldn?t be THAT bad) and was surprised that it didn?t. This whole thing started with a discussion I had with a Verizon employee, who was also having issues with his device. He and I were both looking forward to this phone coming out and buying it as soon as it was available. He was convinced that the problem was hardware and would not be fixed with software updates. I on the other hand was more optimistic of an improvement given what I remember of the Droid Charge last year.
* I am well aware that EM radiation from the body can effect dBm so any time I present these kinds of readings or do speed tests the device is un-cased and lying on the table (or in some cases in a charger dock). I NEVER hold the device when taking the readings.
* The data is presented in this order but the readings were not taken in any particular order, in fact numerous times the Nexus was the first one measured.
* As for the 3G vs 4G dBm measurement if you noticed in one of the posts in the first page Droid800 brought this up and I changed the setting on my Nexus forcing 3G and the dBm was 5 points better, so even if you accept a 5 point margin for error the difference is still compelling. I?m not 100% sure he is completely right there about the other devices since I have seen stark differences with the Bionic when swapping between the two when doing some testing at work when we were trying to find out why the LTE wasn?t working in our building (Verizon later adjusted the towers in the area to make it work most of the time). My Verizon rep certainly believed that changing the setting in the phone changed the dBm reading. But for the sake or argument I am willing to concede that he is probably right.
* I?m actually still collecting data (Nexus forced to 3G) and will release a chart showing another weeks data at the end of the week (Sometime Sunday when I get around to it) but honestly I don?t expect that much of a difference based upon the last two days.
* To those of you who flat out ?don?t believe? my data that is your right I guess, but I would challenge you to look at your own biases. I?m not naive enough to believe that ?numbers don?t lie? but I also know that generally refers to skewed statistics which is why my raw data is presented in the graphic at the bottom of the original post for anyone to read who wants to.
* Those who argue that the numbers must be wrong because you get better signal: Good for you that means you are in a better coverage area. I never said I was in a great coverage area. I could get better numbers too if I went to another room or outside, but that?s not the point. As long as my readings are tall taken in the same place the comparison between them and other devices is still valid.
Let?s keep the discussion going. A couple of you have reacted shocked that the thread has gone on this long and been liked as many times as it has. NEWSFLASH this device has issues, people know it and the discussion isn?t going away any time soon. It is my expectation to keep this tread going until Samsung, Google, and Verizon fix the problem. Everyone is welcome to post opposing views if you want as long as you are respectful about it.
