Results 1 to 7 of 7
    foush's Avatar
    Posts
    Global Posts
    48 Global Posts
    Default Switch between Calls
    Ok...I searched around a bit and can't seem to figure this one out.
    On a call and another call comes in. I answer call 2. When done, how do I get BACK to call 1?
    THANKS!
  2. #2
    Default Re: Switch between Calls
    wait for the person on the other line to hang up lol
    or press what looks like the refresh button
  3. #3
    the other person hanging up doesn't work and there is no button that looks like a refresh button
  4. #4
    bworley50's Avatar
    Posts
    Global Posts
    916 Global Posts
    ROM
    Stock ATM
    Would also like to know an answer to this
  5. #5
    seanubis's Avatar
    Posts
    Global Posts
    186 Global Posts
    ROM
    Stock
    Use the call notification in the status bar?
  6. #6
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,872 Global Posts
    ROM
    BB JB
    Can never get this to work.
    Side note, how to disable incoming call while on one?
    I want to send the second call to vm and yet it keeps ringing when I hit ignore.
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  7. #7
    Found this. Icons mentioned probably won't show up until you have a call in progress with another call coming through. That's all I could find. Hope this helps.
    Attached Thumbnails Attached Thumbnails Switch between Calls-gn-call-options-1.jpg   Switch between Calls-gn-call-options-2.jpg
    Thanked by 3:
