Results 1 to 4 of 4
    Default Stock Nexus Help
    Ok so here is the problem. i have a stock non rooted nexus with a broken screen and nothing displays on it. and when i plug into computer it pulls up phone to a empty folder. is there anyway with out being able to see anything on the screen to either push CWM to it or to somehow using adb to pull everything off of the sd card???? my only other thought was to take apart phone and remove the piece of board with the sim card and scan disk chip and put it into a diff phone to try and move the data off but unsure if that would work. i am not sure if this will test the knowledge off ppl out there but it has surpassed mine.
  2. #2
    Default Re: Stock Nexus Help
    You can give this a shot. I was able to do something similar with it, I'd flashed a file for the wrong phone and pushed my new boot.img to it using this, even when the phone wasn't detected as a USB device by my computer. I'm rooted and ROM'd (obviously) but it may work for you, too.
    Thanked by:
    that is a grat tool kit but i think where the problem is that it is not in debbugging mode and it is not rooted. thanks again though. i will be keeping this for when i get my own Nexus. i am working on someone elses
  4. #4
    Yeah, no debugging mode is pretty much a killer. Maybe some sort of GN wizard will know what else to do, but I think you're boned.
