Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By rob90262
    Droid800's Avatar
    Banned
    Posts
    Global Posts
    3,706 Global Posts
    ROM
    Stock
    Default Random, huge, battery drop
    So I was using my phone on my lunch at work today, put the phone in my pocket, and felt it getting extremely warm over 20 minutes. Took it out, and it had dropped over 40%. I have no idea why, and the battery stats are no help. The only apps I used were Facebook and twitter. (Twitter isn't showing in battery stats though)
  2. #2
    kca2000's Avatar
    Posts
    ROM
    "Shiny" Stock Android
    Default Re: Random, huge, battery drop
    Forgive me, but I don't understand your wording, it was warm for 20 minutes? or this all happened in 20 minutes after putting it in your pocket? Because 40% in 20 minutes is insane!
    Just a guess, was facebook or twitter accessing the GPS for location services? I had the GPS stay on once and facebook was the culprit. Phone did exactly what you describe (Got real warm and severely drained the battery). Although in my situation it took an hour for me to notice it. Did it stop after a reboot? Has it happened since?
    Droid800's Avatar
    Banned
    Posts
    Global Posts
    3,706 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by kca2000 View Post
    Warm for 10 of those 20. It's never happened before.
  4. #4
    I've had that happen a couple of times using navigation. 2 hour ride with the phone plugged in and for some strange reason it would drop to around 40%. Typically I can get in a 2 hour drive and only be down to 60-70% with the phone never plugged in. I have yet to figure what caused the drainage.
  5. #5
    rob90262's Avatar
    Posts
    Global Posts
    424 Global Posts
    ROM
    stock ice cream
    Default
    One time I had just took my phone off the charger played 1 game of draw something and it dropped about 30%
    davey11 likes this.
