Results 1 to 3 of 3
    Default Need help restoring bricked phone
    I was recently playing around with the build.prop and recently got my phone in a bootloop where I can see the flashing multi-color screen but the phone refuses to boot up.
    Prior to doing any changes:
    1) I made a backup of the original build.prop file
    2) Made a system backup in Clockwork recovery
    When I push Power and Volume Up/Down I can get into the bootloader screen but when I select Recovery, I get a picture of an open droid robot with a Red Triangle.
    I need a way to get into Clockwork Recovery so I can flash my backup and restore my phone, or a way that I can use ADB to push my original build.prop file back to my phone, replacing the one I tinkered with.
    Is there anyway to do this in ADB?
  2. #2
    Hovik818's Avatar
    Posts
    ROM
    Stock Rooted
    Default
    You can flash CWM using fast boot. A quick Google search on how to do it should be available (my phone is almost dying, so I can't really do the Google search right now).
    Thanked by:
    Default Re: Need help restoring bricked phone
    Wow.....You rock.
    I knew they always said it was hard to really brick your phone, but adb wouldn't recognize and I was planning to reflash using Odin but knew I'd probably lose all my data and have to reroot/reunlock/reinstall
    I used to have CWM as the default recovery, but went back to the traditional because I didn't want it to prevent me from getting the next OTA update.
    I didn't know it was possible to do much in fastboot mode without using it in combo with ADB.
    Now that I was able to get into CWM and access my backup recovery, it is so much less painless.
    Here's a link for the benefit of others:
    I love you man!!
