Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By JB426
  • 1 Post By zero neck
  • 1 Post By metz65
  • 1 Post By davey11
    JB426's Avatar
    Posts
    Global Posts
    39 Global Posts
    Default This greatly improved battery life for me
    I installed the app BetterBatteryStats to see if if I could pinpoint anything causing my battery to drain. Ran the app and under partial wakelocks, AudioOut_1 was causing a lot of wakes. Upon further research, there is a bug with the sound settings that will cause wakes and thus battery drain. Go to Settings, Sound, and make sure Touch sounds and Screen lock sound are unchecked.
    This has made a significant difference for me. When the phone is asleep I now lose very little battery, whereas before the battery would steadily decrease. Found info on this at xda-developers and from the BetterBatteryStats developer. Hope it also helps some of you.
    Thanked by 7:
    svfd757 likes this.
  2. #2
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Default Re: This greatly improved battery life for me
    Thanks for sharing
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    davey11 likes this.
  3. #3
    ZachDasher's Avatar
    Posts
    ROM
    Redemption Rom
    Ill definitely try this, I saw the audio_out, but never knew what it was... Thanks for the advice
  4. #4
    Default
    Thanks for the heads up.
    davey11 likes this.
  5. #5
    But but I like the screen lock sound. OK OK will try this. Thx
    zero neck likes this.
  6. #6
    Default
    Thanks for the info. I haven't had much time to search the forums for a fix but my sounds haven't worked since I got the phone a couple of weeks ago. All other sounds work except screen lock and touch feedback. Any suggestions?
