Page 1 of 2 12 LastLast
Results 1 to 25 of 36
    Orlanzo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Bluetooth Pairs But No Audio
    I have a stock Galaxy Nexus. It almost never streams audio over Bluetooth. It pairs fine and show media audio is connected, but no music is played. It worked once in a 2011/2012 Dodge Durango. It was fine on the way to my destination. Just the opposite on the return trip - no audio whatsoever after a couple of reboots. Is this an issue with Android in general of the GNex?
    I also tried with a bunch of Bluetooth capable speakers in Best Buy. No luck, but the salesman's iPhone connected and played with no issues. Are the Bluetooth implementations different between iOS and Android? I thought it was a common protocol.
    The only think it works with consistently is the Bluelink2 Bluetooth Music Receiver.
    It's weird and I've seen a number of other Bluetooth issues on the Net.
  2. #2
    dubge's Avatar
    Posts
    Global Posts
    1,384 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing
    Default Re: Bluetooth Pairs But No Audio
    I had this issue as well when I got the phone at launch. I swapped out the stereo in my truck only to find out the newer model of the stereo did not had music streaming. I think someone told me it was 4.02 that was the problem but I cant remember. They might have said it was 4.02 with some bluetooth radios.
    I switched to 4.04 when it first came out and got a new stereo (different brand) and the bluetooth module that plugs into it and can now stream music, though it does cut out a few times a min. I don't know if it was the brand or because I switched to 4.04
    I just finished loading the newer 4.04 build and I am hoping this solves the music from cutting out.
    Orlanzo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's strange dubge. It worked once and never again. I'd assume nothing changed in the vehicle. I hope 4.0.4 is the key. It's an otherwise good phone. This streaming problem is a bummer. I guess I got too excited the first time. It hasn't worked since.
  4. #4
    Small_law's Avatar
    Posts
    Global Posts
    622 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bluetooth is just a wonky sort of technology that's certainly gotten better in the last few years but is far from perfect. My GNex's BT will connect to my car stereo (stock Acura) when I first start my car, but drop the connection seconds later for no good reason just to reconnect again and stay connected. Happens pretty frequently. Other times it connects to the car as a stereo music device rather than both music and hf calling.
    BT is subject to a lot of interference due to its low signal strength. I'm pretty sure BT uses the 2.4 ghz frequency too, which is absolutely crowded with wifi stuff these days. Your problem could be interference related. But I've never had a device that does BT perfectly 100% of the time. Always seems to be some glitch that crops up.
  5. #5
    sdavid631's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have 4.02 and am on my third Nexus- all three paired and playd perfectly on my car stereo via bluetooth- Very strange-
  6. #6
    dubge's Avatar
    Posts
    Global Posts
    1,384 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing
    Quote Originally Posted by sdavid631 View Post
    could be the brand is more compatible
    when I had the droid charge I would lose connection sometimes and would have to turn the radio and/or bluetooth on the phone on/off for it to reconnect. It always happened when I first got in my truck and would do it sometimes 5-6 times in a row, once it stayed connected for over 5-10 seconds it would stay connected no problem
  7. #7
    rufflez's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you checked in your bluetooth settings that you have the right profiles selected?
    Go into bluetooth settings-- hit the settings button next to the item you are paired with and make sure you have media audio selected.
  8. #8
    scabsk8s's Avatar
    Posts
    Global Posts
    94 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have the same problem ,the phone will pair with the kenwood deck in my truck every time & the phone will work but most of the time the audio wont work with music i thought it was my stereo but it does the same thing with my nokia bluetooth headphones ... i hope this problem gets resolved ,i use my bluetooth all the time especially @ work & while driving .
  9. #9
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just thought I would offer that the Plantronics BackBeat 903+ works great for both phone and media. I have used it for like 2 yrs with several devices without an issue ever and it still hold a 7 hr charge great.
  10. #10
    scabsk8s's Avatar
    Posts
    Global Posts
    94 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by zedorda View Post
    Thanks for the input but its the GN that's the problem, I have had my Kenwood Bluetooth deck for over 2 years &have never had any issues streaming with any other devices..I'm hoping an update will fix this issue, it is a big problem for me .
  11. #11
    TabGuy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a similar problem. GN pairs with my Ford Sync but no sound. It's mute. However, my Galaxy Tab works fine.
  12. #12
    rufflez's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Works fine for my JamBox. My car doesn't support Media transfer (2011 Audi A4... which is bull for such an expensive car).
  13. #13
    rbess1965's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by dubge View Post
    I had a Samsung Charge that would connect to my Ford Sync system and play music but it too would skip or mess up often enough it would be really annoying. Didn't matter whether it was using my music player or streaming Pandora but it was worse when streaming. Top of that sometimes I'd loose my data connection while streaming and turning off the Bluetooth was the only way to reconnect data. It was all very disappointing. I really do believe that the Bluetooth radio interferes with the data rf more than anyone realizes. Had that phone for 8 months. I now have the Maxx and I agree the screen is not on par but I promise you the Bluetooth has not skipped a beat on my Ford Sync and data is never an issue unless it's system related. It even does something now that the Charge wouldnt. The ford sync now reads out my messages to me and has canned replies. Its so cool. I love this phone. I'm not trying to bother you guys just relaying my experiences with the two phones.
  14. #14
    aziadeh's Avatar
    Posts
    Global Posts
    36 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes way too often...
    I've had my GNEX since launch day and everyonce in a while it will connect to my Kenwood headunit and says it's playing but no audio.
    What I do is turn the volume (on the phone) all the way down, and back up to just one click below 100% and it works everytime.
    As far as the connection goes, I've never had it stop playing / drop connection. I do live in a saturated 4G area.
    I stream Pandora and listen to Tom Leykis everyday for about 2-4 hours a day depending on where I'm working that week.
    Rooted, custom ROM, 4.0.4 with FC04/FC05 radios
  15. #15
    rcpa's Avatar
    Posts
    Global Posts
    180 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You just have to reboot. It used to happen to me a lot until I started using custom ROMs that were based on 4.0.3 and above.
    Once you reboot, it will work for a couple of days, and then one day it will connect but not play any media. At that point you need to reboot again.
    On the plus side, the Nexus reboots relatively fast.
  16. #16
    mikebear's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use my GNex to connect to my Jaybird headset, an off brand portable BT speaker (in my shower) and my Panasonic head unit in my car, all through BT. All work great. The only time I have issues is in the car when I forget to turn on the BT BEFORE I start the car, then it connects, but only for the the phone and not the music for some reason, so I just turn off BT and turn it back on again and I'm good to go. Also if I gete a phone call, I loose the music BT when the call ends, but not always, sometimes it re-syncs correctly. I am good to go over 90% of the time or more with 3 devices, most used multiple times each day. I love BT and my Gnex.
  17. #17
    walterwood44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Small_law View Post
    I have had this happen with my 2008 Lincoln MKZ and Evo 4G. The BT connection would drop soon after leaving home and my WiFi connection. I was told by the Ford dealer to turn off WiFi before getting in the car. I did this and no longer have the BT connection drop and reconnect.
    BTW, I have no text support with my current car and phone.
    Walter
    looking to replace my Evo with a new GN.
  18. #18
    tuckie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm on a rooted stock 4.0.2, and I've had this bug pop up with my sony bt headphone adapter. A reset of my phone clears it right up.
  19. Thread Author  Thread Author    #19
    Orlanzo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rebooting doesn't work for me. I've tried that a few times. i was really excited when it initially worked. Unfortunately, it hasn't worked since. Either other devices are skewed to support the iPhone or the iPhone has better support for Bluetooth over a broader spectrum of devices.
  20. #20
    TemporalBeef's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I too have this problem. I'm in a 2012 Kia Optima, and it happens if I have bluetooth on when starting the car, or if i turn it on after. I do reboot my phone and it works after that, but let's say i'm listening to some tunes through BT, then turn off my car and turn it back on, it won't work (most of the time. There are times when it will work.)
    Anyone know if 4.0.4 fixes this issue? It's a bit of a pain in the keester.
  21. #21
    loraque's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Surviving through on/off is in my BT experience, app related. PAndora for eample used to be terrible at this (I use Tasker to automatically do stuff including run Pandora when it connects to the car BT). So say I am getting gas, and leave the stereo on to listen while I wait. When I start the car again, the stereo turns off while the car starts, disconnecting the phone, then it starts connecting again once the car is on.
    Over time, this behavior changes, based on Pandora upgrades (for me). It is pretty good at this point, where I just have to tap the play button again to start it up. Sometimes I get odd low volume, where I have to close pandora and re-open. The stock music app handles this situation differently. In my case, I do not believe this to be a ROM or OS issue, but an app issue.
    On mine, 4.0.4 actually breaks BT streaming altogether. I run 3/18 version (4.0.3) just for this reason, though I do have the 4.0.4 radios for the signal performance.
    I am not sure you can lay the stereo restart issue on the phone... exactly. Yours may be different, but mine is all the app's fault .
  22. Thread Author  Thread Author    #22
    Orlanzo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If it is app related, why does Bluetooth connect for some devices and not others? BT works fine using a BlueLink 2. It fails just about everywhere else. Just curious...
  23. #23
    tdi1985's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Pairs just fine for me with my 2010 Mazda 3 (stock stereo). My biggest complaint about pairing is that the audio for Navigation is being pushed to bluetooth audio rather than just playing out of the phone. This means I'll have to flip to BT Audio on the stereo rather than being able to listen to the radio or anything else while I get turn notifications. I can deal with the problem, just a little annoying. All apps should have an option to choose your audio output.
  24. #24
    rcpa's Avatar
    Posts
    Global Posts
    180 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I used to have this problem all the time and rebooting would fix it for a day or two. However, I have not seen it since rooting and loading custom ROMs based on 4.0.3 or above. So it appears it was fixed in 4.0.3.
  25. #25
    sirmikey3111's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a chevy equinox and a motorola razr maxx which I can pair through Bluetooth just fine but Pandora plays on the maxx but not on the car stereo? Any help would be mucho appreciated!! Tahnks,Mike
