Results 1 to 6 of 6
- 05-04-2012, 05:55 PM
Thread Author #1
- 05-04-2012, 08:18 PM #2It is better to be pissed off than to be pissed on!Thanked by 2:
- 05-04-2012, 09:35 PM #3
Re: IMM76K for locked & unrooted issue
The new radios have got me better signal and drastically better handoff between wifi-3g-4g
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 05-05-2012, 12:18 AM
Thread Author #4
- 05-05-2012, 01:06 AM #5
- 05-14-2012, 04:36 PM #6
I can not get this to work on either of my units. ! unit has the ICL53F and the othwer has the imm30B on it. I followed this: and It will not work. This is what I get exactly: I dropped the update.zip on the root directory of my internal storage, then power the device on while holding both volume keys.Then select Recovery mode. I get the Google screen and then the android guy laying down with the red caution symbol. I press volume up and power to get the menu and I select: apply update from /cache. All that is there to select is either : ../ lost+found/ or recovery/. So what am I doing wrong here? My unit are stock and untouched so I should be fine?
Reply
