Results 1 to 7 of 7
- 05-09-2012, 01:03 PM
Thread Author #1
How can you reset the Screen Lock from Face Unlock with lost pin?
Greeting.
I am new to the forum and just recently purchased the Galaxy Nexus. I have locked my phone, installed the Screen Lock Bypass but it didn't work. I set my screen lock to face unlock and used the pin as backup. The pin I thought I set is not working and now I am unable to change the screen lock. I have been unable to get it to recognize my face, so it reverts to the pin and will not allow me to get pin. It only says I have tried so many times with the incorrect pin and to wait 30 seconds and try again. What can I do?Last edited by VZMSUser; 05-09-2012 at 01:05 PM. Reason: incomplete information
- 05-09-2012, 01:14 PM #2
Re: How can you reset the Screen Lock from Face Unlock with lost
i think if you enter your pass incorrectly to many times it will ask you to enter your Google log in information and let you in to the phone when that is entered correctly. From there you can change your security set up.
That worked on my Droid charge, never had the problem with Nexus...but i think it works the same way.
Edit:
just checked, once you get the message "please try again in 30 seconds", hit ok and A button will pop up on the bottom that says "forgot your pattern", click that , you can enter your Google log in and access the phone.Last edited by bakerbert; 05-09-2012 at 01:21 PM.
Sent Via..Raven from Kings Landing
BB Storm 1 > Samsung Droid Charge > Samsung Galaxy Nexus > Samsung Galaxy Note II - 05-09-2012, 01:27 PM
Thread Author #3
- 05-09-2012, 01:38 PM #4
EDIT, Sorry you had pin not pattern.
not sure about this, looking about how to do this. there has to be a wayLast edited by bakerbert; 05-09-2012 at 01:55 PM.
BB Storm 1 > Samsung Droid Charge > Samsung Galaxy Nexus > Samsung Galaxy Note II - 05-09-2012, 02:18 PM #5
- 05-09-2012, 03:50 PM #6
- 06-28-2012, 03:04 AM #7
Reply
