Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By TJH132
    Default phone heat up while not using it.
    my galaxy nexus phone heats up when im not using it and its causing the battery to drain... is there something wrong with my phone or do i need go to to settings to change something? usually when i shut the phone off and turn it back on in a few minutes it fixes the problems but later during the day or early morning it warms up again.
  2. #2
    Nakrohtap's Avatar
    Posts
    ROM
    CM10.1 Fitsnugly AOKP
    Default
    Depends if your phone is awake or not. Just because you're not using it doesn't mean it's not doing anything. Check your battery stats first. If it's awake when it's just sitting there, then you just need to find out what app(s) are keeping it awake.
  3. #3
    Default Re: phone heat up while not using it.
    BetterBatterystats can help you track it down.
  4. #4
    Default
    it is almost always an app keeping your phone awake. If there have been some recent apps you have installed, start by uninstalling those one at a time.
    Or, look at location aware apps first. They seem more likely as culprits in my experience. Latitude, weather apps,or anything else that wants to know where you are. Turn off GPS for a while and see if it cools off for a good blanket test of that cause.
  5. #5
    I was in a movie theater last weekend with virtually no service (4G outside, nil inside). When the movie ended, my battery was drained by half and the whole phone was hot to the touch. No evidence, but I suspect it tried connecting to the network the whole time it was in my pocket. Next time, I'll click Airplane Mode and save the juice. (My wife's iPhone was similarly drained but not hot.)
    Are you in a 4G/3G area? It could be using extra resources going back and forth between the two. Try a day on just 3G and see what happens.
    TJH
    loraque likes this.
