Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By McSlappy
    Question Galaxy Nexus Extended Battery
    In a nutshell, I have purchased the OEM 2100mah Samsung Battery and now I am currently using a Hyperion Electronics 3800mah Extended Battery in my Galaxy Nexus. Even with the 3800, i can max out at about 19 hours with moderate to light use. I am looking to purchase a battery that will allow me to have heavy use all day and not have to worry about finding a charger as soon as i walk in the door when I get home. Any suggestion? Is my poor battery life currently because my battery is generic? Help is appreciated! Thanks everyone
  2. #2
    Default
    I would guess yes.... get the official one....
    Just my opinion
    D
  3. #3
    Default Re: Galaxy Nexus Extended Battery
    I don't see how you can accomplish more other than by using an external battery charge like this one [\
    If I know I won't be near an outlet for a long time I wear it on my belt in a small generic phone case.
  4. #4
    McSlappy's Avatar
    Posts
    Global Posts
    113 Global Posts
    Quote Originally Posted by itstilleytime View Post
    Any suggestion?
    This "might" break the 24 hour mark with this phone.
    samkatz likes this.
  5. #5
    If you aren't seeing 24 hours of use out of that 3800 mah battery, my only other idea would be to get an external battery like the ones by Mophie (4000 mah). That and the oem 2100 mah or that 3800 mah will definitely do the trick.
  6. #6
    SuperMarioVT's Avatar
    Posts
    ROM
    Bugless Beast -Jelly Bean
    Welcome to the GNEX life.. you are lucky to go past 4pm if you are on 4G
    Sad but true..
  7. #7
    1fastmr2's Avatar
    Posts
    ROM
    Default
    The battery on that phone with a very large screen was terrible for me
    Sent from my DROID RAZR using Android Central Forums
  8. #8
    Battery life has to be due to individual usage. My GNex has been off the charger for 14 hours and it isn't showing the low battery indicator. I used it pretty sparingly today except for over 90 minutes of streaming podcasts over Bluetooth in the car. I don't have a lot of things turned low either. Battery does go fast if I use YouTube a lot though.
  9. #9
    andrewshah's Avatar
    Posts
    Global Posts
    377 Global Posts
    ROM
    AOKP/Franco
    Default
    I wish I could find something similar to what I used with my Fascinate.
    I bought the pack off Amazon, it came with 2 batteries and an external charger.
    They weren't extended, but being able to carry around 3 batteries always fully charged (thanks to the external charger) definitely got me through the day with very heavy usage.
    IG= @andrewshah_ru
  10. #10
    2200mAh Power Back Case External Battery for Samsung Galaxy Nexus
    This gets me through a whole day with heavy use and I only have the stock battery.
  11. #11
    battery will go all day (from 8am central to about 12pm central) at moderate use, thats txting alot at work, hardly any if no actual calls (calls REALLY KILL BATTERY) heavy browsing in 15 min 2x a day (15 min work break). Works great when come home till around mindnight. Now if i know im going out that night, ill charge when home from work (things charges SUPERFAST compared to my thunderbolt, moto driod og. like 20 mins from red will make it 50%...
    -Verizon Extended Battery
  12. #12
    please see my post in reception thread (last two posts and let me know what I should do)
  13. #13
    Default
    8am to 12pm is only 4 hours...
  14. #14
    Default
    Quote Originally Posted by king43 View Post
    was on the phone for an hour and a half just now, went down to 80%
  15. #15
    Default
    I have the imp70 charger from New Trent and my olny problem is it charges so slow. It charges as a USB not AC.
    I have had the best luck with my aftermarket Anker 2200 mah which lasts the whole day.
    Of course that is with Juice defender plus running.
    Is there a portable battery that charges in an AC speed as if it was plugged into the car or outlet?
    I did use both the 1a and 2.1a output ports and it is still slow.
