Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By dmmarck
    Kegman's Avatar
    Posts
    Global Posts
    224 Global Posts
    Default Verizon Nexus OTA 4.0.4 red triangle exclamation point
    I am rooted and have an unlocked bootloader but have stock rom and stock kernals and stock radios.... everything else stock.
    I get the "new update available" OTA click to restart and the phone restarts. I get the android with a blue spinning something in his back with the progress bar moving. at about 25% it always changes to the android on his back with a red triangle exclamation point. Nothing happens from here.
    I can do a battery pull and get the phone to start fine again.
    I've seen these problems in other posts, but theres always something thats not the same as my phone for example the person flashed a rom or kernal. I have not.
    any help?
  2. #2
    Default Re: Verizon Nexus OTA 4.0.4 red triangle exclamation point
    Did you delete any of the preinstalled apps?
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Do you have stock recovery or CWM?
  4. #4
    Jet300's Avatar
    Posts
    Global Posts
    403 Global Posts
    Default
    Quote Originally Posted by dmmarck View Post
    I have the same problem. I have CWM .. I assume we need to flash back a stock recovery??
    If so... How do I easily do that ? Thanks!
  5. #5
    Default
    I have the same problem under the same circumstances. How do I flash back to standard recovery?
  6. #6
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    There's been a few posts on this scattered about. You need to use fastboot or a toolkit to flash the stock recovery.
    Or you could install the OTA manually.
  7. #7
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    524 Global Posts
    ROM
    Stock
    I had a similar situation and prior to using this method I renamed the "recovery-from-boot.p" file and removed the .bak extention from the end. I then tried the three step and got the red triangle. After reboot I repeated and all worked this time.
    Edit: Using Root Explorer
    Thanked by:
  8. #8
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    Quote Originally Posted by Cigar_Junkie View Post
    That will work if the file has not been deleted and merely renamed with the .bak extension. If the file has been deleted, you have to flash it back.
  9. #9
    I had the same problem and found a method so you don't have to flash stock and lose root.
    Just skip the wiping data step, but I did wipe the cache. I also backed everything up just in case tho. So far everything's been great!
  10. #10
    Jet300's Avatar
    Posts
    Global Posts
    403 Global Posts
    Default
    Hmmm.... I just checked using Astro and recovery-from-boot.p is there .. no .bak extension.
    I have Nova Launcher installed as a system app from back in the beta days... would that affect the ability to apply the update file and cause the red triangle?
  11. #11
    Jet300's Avatar
    Posts
    Global Posts
    403 Global Posts
    Default
    Quote Originally Posted by sutrebla15 View Post
    This will give a fresh install ... not apply the update.... Correct?
  12. #12
    Quote Originally Posted by Jet300 View Post
    That is the 4.0.4 update. You don't have to wipe your data if you are running stock and not any custom ROMs. I was able to keep everything as is on my phone, including root.
  13. #13
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Yes. Please see our guide on doing this. It's located in my signature.
    If you want to keep root, you must flash the updated superuser app.
  14. #14
    This way worked wonderfully!!!! Thank you!!!!!! Question does anyone know what the new Dock menu is for in the settings menu? Just curious. Thanks!
  15. #15
    kenshell's Avatar
    Posts
    Global Posts
    194 Global Posts
    Sorry to sound so stupid, but being I'm only rooted and unlocked, can I simply let 4.04 install OTA?
  16. #16
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by kenshell View Post
    Do you have the stock recovery or a custom recovery like CWM?
  17. #17
    kenshell's Avatar
    Posts
    Global Posts
    194 Global Posts
    I used Wug's Galaxy Nexus Root Toolkit. I'm guessing that is stock?
  18. #18
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I'm 95% sure that Wug's flashes CWM onto your phone. You need to flash stock recovery back.
    To check, power down your phone then hold down volume UP, volume DOWN, and POWER. That gets you to the bootloader. Once in the bootloader, use the volume buttons to make a selection. Find "Recovery," press the power button, and then let me know what you have.
    If you have CWM, you need to flash the stock recovery using Wug's or fastboot. There's a bunch of threads floating around re: how to do that.
    GNex Girl likes this.
  19. #19
    GNex Girl's Avatar
    Posts
    Global Posts
    736 Global Posts
    ROM
    stock 4.0.4
    This is correct.
  20. #20
    mozy's Avatar
    Posts
    Global Posts
    332 Global Posts
    What folder does the stock recovery file go?
  21. #21
    kenshell's Avatar
    Posts
    Global Posts
    194 Global Posts
    hell..... that worked great. lol
