1. bespinct's Avatar
    I didn't think the GNex would allow tethering and a phone call at one time. I was pleasantly surprised tonight to discover that I could continue browsing Android Central on my computer while chatting with my wife.
    Is anyone else surprised or am I just late in getting the memo?
    Steve in CT
    06-06-2012 09:38 PM
  2. phattysalz's Avatar
    4g allows voice and data at the same time so it makes sense. I also tried it out a while back. Talked on the phone while watching slingbox on ipad that was tethered to phone via wifi.
    If you are on 3G connection on your phone, I don't believe it works. Your data will cut out for the phone call.
    06-06-2012 10:32 PM
  3. cj100570's Avatar
    You are correct. LTE is data only so you're able to use it while voice goes over the CDMA network. You can't do simultaneous voice & data via 3G.
    06-08-2012 01:03 AM
  4. bespinct's Avatar
    For some reason I thought only the thunderbolt allowed voice and data at the same time. I don't have LTE at home, so I wouldn't have had the opportunity to try it before now.
    Steve
    06-08-2012 07:11 AM
  5. Channan's Avatar
    If you weren't connected to LTE, then you must have been connected to Wi-Fi. The Verizon Nexus doesn't have the hardware for simultaneous voice and data over 3G.
    Unless you're saying you were on 4G and I'm misinterpreting your post.
    06-08-2012 10:18 PM
