WiFi Problem after 4.0.4 update
h2opoloplyr_11
153
8
Just updated my phone to the 4.0.4 update (via OTA) And everything seems to work just fine.
But my new problem is that everytime i am on wifi, google play store would not download / update apps instantly. I usually have to wait at least 2 minutes before the blue "downloading......" bar starts to move. It stays on the blue / white line dashing across for about 2 min.
I tested 4g, and it seems to work just fine. update and installing new apps downloads right after i click download or update.
Weird thing is that before (with OS 402) both wifi and 4g would work just fine.
I have tried doing a factory reset with clearing cache via bootloader and the problem still persists.
Anybody else having this lag / delay with the app store with wifi? or is it time to try and see if i can get my phone switched?
**UPDATE**
Now even the Facebook app isnt loading pictures when i click on them.....it does the loading circle on the black screen for about 1 to 2 minutes then it finally loads......
but switched to 4g, then most pictures i click would load right away.
Tried to download an app with my sisters Nexus S on the same wifi network, (4.0.4 stock) and she was able to download instantly. Also with my moms Galaxy Note (stock) on the same wifi network.....again same thing...instantly. Its just my GNEX.
Also did a speed test with the wifi on (to make sure that my wifi speed isnt at a dogs pace)
Ping:58ms
Download: 9.2mbps
Upload: 1.3.mbps
Thanks.
dsignori
2,540
40
48
I am noticing some of this, though quite intermittently.
I still am not sure if I do see it, but the 2 times I noticed, I switched to 4G and things moved right along - as you mentioned. I'll keep monitoring mine to see it this continues ..
fallonjp
10
I'm having an issue similar to this, although not with the Play store. When receiving a text with a picture, the picture will not download while on WiFi. The other problem I'm having is that new gmail messages don't seem to be coming through as they should. I've had to pull to receive messages a bunch of times.
_JKK_
586
26
Try forgetting the network by long-holding on its name in the settings.
Also, I may be wrong, but I think that Verizon only downloads photos over their network as that's the only one they can assure security over. I remember reading about that.
ScandaLeX
487
59
It may not be a problem specific to your network or phone. My SG2 (Sprint) ICS 4.0.4 does the same thing. Connected to wifi 99% of the time and downloads of any kind don't start right away.
Even using apps like tapatalk don't pull in replies to subscribed threads unless I open the app first.
Same with gmail. Have to open it to receive mail. None of this was a problem before ICS.
Tappin' from my SGP 5.0
tayswg20
131
20
**UPDATE**
Ping:58ms
Download: 9.2mbps
Upload: 1.3.mbps
Thanks.
I found a solution. At least it worked for me. Maybe it'll work for you as well. http://forums.androidcentral.com/verizon-galaxy-nexus/179707-wifi-issues-d-link-router.html
Small_law
620
34
That's strange. I'd suggest setting a static IP if you try connecting directly to the router again. I haven't seen this issue with my Asus router at all.
Is the problem the same on 2.4 ghz and 5 ghz if you have a dual band router? It could be any of a number of things that just aren't playing well.
Edit: I have seen an old issue crop up when trying to update apps, the one where it shows an update is available but all you get is the option to open it. It's happened for me on wifi and mobile data, but it may be something with the market itself on 4.0.4.
tayswg20
131
20
I did try using a static IP as well but that didn't work for me either. I also tried setting my phone to only 2.4ghz and not auto which made no difference either. Since my router is only 2.4 ghz i couldn't change it on the router. I even tried changing channels on my router one by one and rebooting the router and my phone after every change lol. But, so far it seems like the connectify me thing is working flawlessly. I keep my laptop on most of the time anyway so its not too big an issue. It saved me having to buy a different router and/or phone.
noseph
Active member
Feb 9, 2012
31
I started having wifi speed issues after 4.0.4 update. My download speed, when connected to either my Netgear 54g 2.4Ghz G or my Asus RT-N56U 2.4Ghz N, have dropped to ~2500kbps. My TouchPad running CM9 registers ~25mbps on the same access points. My Galaxy Nexus when connected to my Asus RT-N56U 5Ghz N registers ~21mbps. Would really like to be connected to 2.4Ghz instead of 5Ghz because of 5Ghz lack of range.
Small_law
620
34
I have an Asus RT-N66U and I do see the connection speed on 2.4 ghz vary all over the place, from the max 65 mbps (GNex maxes out at that on either 2.4 or 5) to as low as 6 mbps. On 5 ghz it's a stable 65 mbps. The N66U's firmware is crap at the moment, but it is interesting to see the same problem on the N56 which is a solid performer.
It could be from interference on 2.4 ghz.
noseph
Active member
Feb 9, 2012
31
I just find it strange that this started after the 4.0.4 update and my TouchPad (CM9 Alpha 2 0604 Official Nightly also 4.0.4) is a solid performer on 2.4.
emcdonald75
9
I am having problems with the Verizon Galaxy Nexus even after the 4.0.4 update. My phone only randomly rebooted once, but the battery life is horrible. I have to recharge my phone 5 times per day minimum and that?s with the 2100mAH extended battery. I attribute all of my problems to the radio. The radio signal bounces from 4 bars to 0 bars all day long. The radio also jumps back and forth from 3G to 4G whether if I am using the Internet or not. The data will stall badly. I have the issue with the mic cutting out during phone calls. My friends tell me that during a call I am there one moment and gone the next. I didn?t know what the issue was until I read about similar reports with other people. I also have poor Wifi range, the Wifi data stalls, MMS messages do not download and Google play store does not update apps when WIFI is turned on. This is the worst phone I have ever had, but I love the HD screen. Even the store reps witnessed how terrible my phone was with the poor signal and data stalls, and they told me that the 4.0.4 update would fix my problems. That was obviously a lie. I would leave Verizon but I get Unlimited talk/text/10GB of data each month for 100 bucks. I am in the Jackson, MS, market. I am hoping that another update will be released to fix these issues. I might purchase the HTC Rezound off Ebay because I am afraid that my plan will change to these new shared data plans if I sign another contract. I really want the Motorola Droid Razr HD. Plus, I heard that the Rezound has an excellent radio.
noseph
Active member
Feb 9, 2012
31
Before you use Ebay you should check out Swappa (Android) Buy and sell gently used Android devices and specifically Swappa (Android) Search. I have had excellent results there.
h2opoloplyr_11
153
8
Sorry I have been out for awhile. Busy with work and what not.
But anyways. Yes I was using the same d link router before the 404 update and it worked fine. But after the update it went wonky!
Thank you for all the suggestions and sorry that a few people are having problems as well!
I finally fixed the problem. I went into the router settings and found out that my firmware on the router was last updated back in 09. It was a long shot, but it wouldn't hurt to update the firmware. Now running with current firmware and the app store is running back, to normal again.
I suggest everyone to try and see if there is an update for your router and that might help.
Thanks again everyone.
Bhavan
Hi the problem is simple. Just change the channel from automatic to manual in your wifi router settings. playaround from 1to 6 and 12. your phone will start connecting to one of them. Mine was in 6 and now changed to 1 and now my gnx connects.
Bhavan
2bMobile
You could be suffering from a Wi-Fi DHCP bug that appears to be affecting Android versions 2.1 - 4.x on several devices. The bug was reported to Google by Princeton University back in Sept of 2010. You can check out the device list and Android version on the open bug report (Last updated by Princeton on Sept 11, 2012) at Issue 11236 - android - DHCP client ignores lease time - Android - An Open Handset Alliance Project - Google Project Hosting
For the techies you can check out Princeton University report on the bug at Android 2.1 - 4.0.4 Allows DHCP Lease to Expire, Keeps Using IP Address
Finsrepair
