1. Iccullus's Avatar
    Hey All - Looking for some help - My Samsung Galaxy Nexus is constantly displaying currently running processes on screen. They are displayed in the top right hand corner of my phone and they are updating with whatever I'm doing on my phone at the time. Not sure how this happened as I didn't notice it occurring until I was coming back to work from lunch this afternoon. I think this somehow happened when it was in my pocket. My phone is stock Verizon - No root. I've attempted to reboot multiple times and remove the battery but active processes are still displaying on screen. Tried searching around the internet for answers but so far I've been unsuccessful so I've decided to go to the experts. I've attached a screenshot.
    Does anyone know what I did to get my phone to do this? And more importantly does anyone have/know a trick to stop it from happening?
    arsakasra likes this.
    06-13-2012 07:28 PM
  2. bwilliams22685's Avatar
    Settings>developer options. one of the check marks sets this. I think its show CPU usage
    Iccullus, fgarcia10 and arsakasra like this.
    06-13-2012 07:57 PM
  3. Iccullus's Avatar
    Excellent - that worked - Must have inadvertently checked it in my pocket while I was walking around - thank you.
    06-13-2012 08:00 PM
  4. Aswathy Balan's Avatar
    Thank you.. now problem solved...
    08-13-2014 07:54 AM
  5. mobitrix's Avatar
    i had recently this same disturbing issue of phone processes list running on top-right of the home screen of my Motorola Razr XT 910 on ICS (4.04) after putting it the phone in the pocket . Happened nevertheless the home screen locking ! Solution Worked : Go to Settings - Developper Options - Show CPU Usage (disable) .
    10-19-2014 09:47 AM
  6. kalanifrommaui's Avatar
    Thanks - Very Helpful
    12-05-2014 03:12 PM
  7. rinks4jeet's Avatar
    thanks brother it worked for me
    12-25-2014 01:39 AM
  8. Doc V2's Avatar
    I'm having this problem with my S5. I turned it on but now I want it off. I can't find the developer screen in my settings.
    01-09-2015 06:39 AM
  9. Siddharaj Nimburge's Avatar
    I have ASUS Zen5. As per your solution I did not found developer setting option in setting menu. Please help me
    01-14-2015 06:37 AM
  10. Cel Calimlim's Avatar
    the phone details display in the screen please help me to remove.
    03-08-2015 10:29 PM
  11. Rosado Elcerebo's Avatar
    Thank you so very much... extremely annoying problem. I had a really difficult even finding what to type into Google to begin to find the solution for this. I cannot possibly think of how it happened. There is a trick to even enable Developer Options on a Samsung Note 4. Some app must have triggered it, it is the only way it could happen.
    05-15-2015 07:36 PM
  12. John Shallow's Avatar
    Phone Processes are Showing On Screen of my Asus Zen5 . Please help me remove them
    07-01-2015 09:11 PM
  13. Anisur Rahman Titu's Avatar
    Resolved, Thanks a lot
    08-03-2015 11:53 PM
  14. Anas Shahid's Avatar
    HW unwanted information is displaying on my home screen samsung galaxy s2
    12-04-2015 09:42 PM
  15. padero's Avatar
    Thanks a million it works like a CHARM
    12-25-2015 09:22 AM
  16. habeebulah's Avatar
    thanksalot
    04-17-2016 02:48 AM
  17. pankajhiwrale's Avatar
    Hi, I have samsung core II mobile and problem is Phone Processes are Showing On Screen
    I dont have developer option in setting so what to do?
    please help me???
    05-16-2016 10:18 PM
  18. zawadi 12's Avatar
    please help me???
    the solution is simple if ur phone doesnt have the developers tools option. just go to the about phone option then tap the build number option as many times as possible then ur phone will notify you that the developers tools option is now available.
    Akekala likes this.
    06-02-2016 06:44 AM
  19. Carla Sachetti's Avatar
    Thanks, this solution waorks for my Galaxy Note 5 as well.
    07-04-2016 08:09 AM
  20. Akekala's Avatar
    Same thing happened to me after installing some app. At first it looked pretty cool until the moment I could see vital info on the top right corner. Searched the entire web for solutions but I couldn't find the developer options....thanks a lot everybody who also had a hand in this whole mess. Feels good looking my screen now... Was almost factory resetting my phone
    04-01-2017 11:03 AM
