07-12-2012 06:13 PM
38 12
tools
  1. ItnStln511's Avatar
    Has anyone else had issues with their Galaxy Nexus dropping all connections? For example, my Galaxy Nexus will routinely drop both WiFi and the 3G/4G signal. Is anyone else having this problem?
    07-07-2012 09:42 AM
  2. yodatom10's Avatar
    This has been a reported issue with some gnex. Time to go to Verizon and get it replaced
    07-07-2012 11:19 AM
  3. EJT's Avatar
    Yep. It's a known issue. Get your phone replaced.
    07-07-2012 11:26 AM
  4. ItnStln511's Avatar
    Dang! Will Verizon ship me another Galaxy Nexus, or something else? Any idea if the issue is hardware or software?
    07-07-2012 12:01 PM
  5. ItnStln511's Avatar
    That's what I was afraid of...thank you!
    07-07-2012 12:01 PM
  6. yodatom10's Avatar
    Its hardware. Call there 1800# and they will ship one to you. And when they ask you to do a factory reset just tell them you already did it. A reset won't fix it and it will save you time
    07-07-2012 12:27 PM
  7. ItnStln511's Avatar
    I did a factory rest earlier this week and it didn't help at all. I'll give them a call. I hope that they'll send me another Nexus, or at worst a Rezound. I'm not a Motorola fan after having six Droid 2's.
    07-07-2012 01:21 PM
  8. ultravisitor's Avatar
    If it's within warranty, they'll send you a new one. Some people went through several before getting one that workedl
    07-07-2012 01:23 PM
  9. ItnStln511's Avatar
    That's crazy.
    07-07-2012 01:30 PM
  10. ItnStln511's Avatar
    I'm on hold with tech support now...hopefully it'll work. They wanted to just mail me a new SIM card out, but I made sure that he knew that it was an issue on WiFi also.
    07-07-2012 01:48 PM
  11. radar320's Avatar
    I bought my nexus on 7/3/12. On 7/4/12 I went back to Verizon because of issues with no service. They replaced the sim card. This did not change anything. On 7/5/12, I did some playing around with the phone and found that if I kept the phone on CDMA mode only, I had no drops in both 3g and 4g markets. As soon as I went back to LTE/CDMA mode, I lost all service. Yesterday I went back to Verizon with this information and they switched it out for a new Nexus right there in the store. I have only had one drop since the exchange.
    07-07-2012 03:12 PM
  12. The_colombian's Avatar
    I've been reading that its a hardware problem but I took mine in to the verizon store yesterday and they swapped the sim card out and it has better connection at home. Not sure about work yet but I will now by Monday.
    07-07-2012 03:49 PM
  13. ItnStln511's Avatar
    Would the SIM Card affect WiFi though?
    07-07-2012 05:12 PM
  14. Patrick Schroedl's Avatar
    It would not -- at least, it's highly unlikely. Are you running stock, or a custom ROM/kernel?
    07-07-2012 05:20 PM
  15. ItnStln511's Avatar
    I'm running stock.
    07-07-2012 05:22 PM
  16. radar320's Avatar
    Come to think of it, I had issues Thursday keeping wifi connection. Sounds like you are in the same boat I was in, and have a defective phone. I would get a new one.
    07-07-2012 05:50 PM
  17. ItnStln511's Avatar
    They're sending me another one...I should have it by Tuesday.
    07-07-2012 07:20 PM
  18. sicario666's Avatar
    Don't forget that the Verizon fixall is the good ol factory reset. Which isn't true. Obviously
    Bounced off of my JellyBelly into your eye.
    07-08-2012 12:45 AM
  19. zrxoa1's Avatar
    I don't see it being hardware since it is happening across all android phones on Verizon. My stock Rezound can't keep a 4g signal now for a few weeks. Before that I had no trouble. I say it is on verizons end.
    There is a clause in the contract which specifically states any systematized transmission indicating a possible intelligent origin must be investigated. --Ash
    Revolutionary likes this.
    07-08-2012 01:42 AM
  20. ItnStln511's Avatar
    Yeah, no kidding there!
    07-08-2012 07:01 AM
  21. ItnStln511's Avatar
    That I didn't know...thanks for the tip. Mine did get worse after that storm earlier this month. I'm not sure if it's just a coincidence or not.
    07-08-2012 07:02 AM
  22. ItnStln511's Avatar
    And I just got my refurbished Galaxy Nexus in the mail today. Would you believe that the problem is WORSE on the replacement device?
    07-09-2012 09:25 PM
  23. Silent Patriot's Avatar
    Is it a Verizon Galaxy Nexus? Then, yup!
    07-09-2012 10:49 PM
  24. ajnevares's Avatar
    Same here, I'm on number 3 and still having the issue, but in all fairness Nexus #2 did not have signal problems on 4G, just #1 and #3. #2 had a terrible screen,anytime I switched to an app with a light colored screen, I can still see the imprint of the icons on the home screen. Also, the colors seemed very dull.
    Phone is pretty amazing on 3G and Wi-Fi, too bad Wi-Fi is limited where I am and 3G is slow
    07-09-2012 11:54 PM
  25. Gordo1603's Avatar
    My wife has been having issues with her's as well. Verizon said there is a known issue for this and they are working with Samsung on a fix. Unfortunately they have no eta on the fix though. They said reset will not fix it and a new sim doesn't help either. I had another one sent out but it was just as bad. I sent the second one back and kept the original since it was brand new... Guess we hurry up and wait...
    Sent from my Thunderbolt.
    07-10-2012 12:28 AM
38 12
