DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 3 of 3
    Default help! Gmail on GNEX crashed, can't fix
    My gmail widget is blank, I can't open gmail from the shortcut or any other way on the device. I tried going into APPS, force stop, clear cache, did not help.
    I rebooted the gnex twice, problem not solved.
    My data connectivity is ok, other e-mail clients, eg yahoo, verizon mail, are retrieving mail
    Any ideas? I didn't really change anything at all on the phone today.
    Thanks much
  2. #2
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: help! Gmail on GNEX crashed, can't fix
    Quote Originally Posted by samkatz View Post
    Thanks much
    Did you try uninstalling it? What about unsyncing Google services then resyncing?
    Thanked by:
    It resolved w/o uninstalling. I also kept getting an error message about Volume+ not working, so I uninstalled that. Have no idea if there was any relationship,, maybe memory issue, but it's ok now. tx for your response.
