11-06-2012 09:45 PM
43 12
tools
  1. eric3316's Avatar
    I'm seriously considering about sending this phone back to verizon. How would I go about locking back up the boot loader, and unrooting the phone? Thanks for any help guys.
    http://forums.androidcentral.com/ver...7-14-12-a.html
    07-19-2012 05:47 AM
  2. moosc's Avatar
    They said that back in Jan. And it took 5 months for them to release 4.0.4 the software there talking about this time is 4.1.1 jelly bean which should drop in couple months. This is vzw issue Samsung phones suck on the radio side.
    Just got done with talking to Verizon for the third time this week about this issue...
    Verizon has said that this is a known issue and they officially as of July 16th are working on a new software release to fix this issue and will not replace my device. This being a Network issue they will be doing this as quickly as possible...
    I am hoping that this will fix my issues... Just hope that it will come out soon...
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    07-19-2012 06:01 AM
  3. col_forbin's Avatar
    Went to Verizon today and they said that it is a software issue they are currently working on....couldn't give a time line. They said it appears to be a 4G issue directly. I switched it strictly 3g about two hours ago and have had no dropouts to speak of. I know that defeats the purpose of having a 4G phone, but I least i can make calls now.
    07-19-2012 10:01 AM
  4. Ridgerunner20's Avatar
    Hey guys, here's a good example of that's wrong with my phone. Notice, I have no 4g or 3g at the time I took the screen shot (It was also that way every time I got up last night). Also, I went from a full charge to fourteen percent in six hours, that's sad (With very little use). One more thing is the awake time, I bet all the time the phone was on, I had no signal. Almost all of my phones I've had have this problem to a greater or lesser existent. Any thoughts on a fix or should I just replace it? Thanks.
    Edit, as of the moment I have no signal
    07-20-2012 11:51 AM
  5. smbrooks32's Avatar
    I agree with you on that the 0 9 did not have those issues I actually received the replacement last month it had to build number of the I 515.09 my current 1 is on at 10 the only thing with the 09 was the power cycling on and off
    07-20-2012 01:46 PM
  6. whitewallman's Avatar
    Just a follow-up.. Verizon network teamed called to inform me that this issue is confirmed to be a software related problem on the affected devices and Verizon with the assistance of Samsung will be releasing a software update to address it.
    07-20-2012 02:15 PM
  7. Ridgerunner20's Avatar
    I really hope it's sooner rather then later. Did they give an eta? Days, weeks, months?
    07-20-2012 04:48 PM
  8. smbrooks32's Avatar
    The ETA will be next year I'm sure so get ready for nothing
    07-20-2012 11:09 PM
  9. whitewallman's Avatar
    Just "soon". But at least the problem is acknowledged. A temporary workaround is in network mode, choose cdma rather than lte/cdma. At least the signal drops will stop.
    07-21-2012 01:14 PM
  10. spltngheadache's Avatar
    Mine is on a truck right now on its way .. I won't receive it until Friday. I'll let you know when I receive it what its details are and my success with it.
    I may have gotten lucky .. the tech rep I spoke to had a Galaxy Nexus personally and has experienced the issue so he was very willing to help. If one rep isn't helpful maybe try calling back and see if you get someone else? Again good luck
    I got my replacement. while 4G is seemingly fragile driving around town -- its rock solid staying in one place. The new one is hardware version 12.01 -- old one was 11.12. I don't know if that makes a difference. I'm happy with this one.
    07-21-2012 02:48 PM
  11. smbrooks32's Avatar
    Well jelly has no binary codes in it
    For radio improvements, its mostly about UI layout enhancements so I don't understand why VZW would be dragging there feet. Unless there so understaffed in that department for testing software.
    07-21-2012 05:49 PM
  12. wshwe's Avatar
    I had worse issues with my Stratosphere. Some RAZR owners have had similar issues. The best explanation I've seen is the LTE chip sets are relatively new. 3G had the same growing pains when new. Hopefully next generation LTE chip sets won't have these problems. Verizon was one of the first big carriers to implement LTE.
    07-21-2012 07:20 PM
  13. smbrooks32's Avatar
    This is the best explanation iv seen around
    http://www.androidpolice.com/2011/12...g-data-signal/
    07-21-2012 07:58 PM
  14. zyeagle17's Avatar
    Get a new provider.. If your phone is always searching no matter the device, it's the service. No matter the device, if it is always searching for service it will die wayyyyy faster than it should.. wake up dude and look into a new service.
    09-08-2012 02:01 AM
  15. urquattro83's Avatar
    Another problem my phone is having is insanely bad battery life. For instance, I can go to bed with a full charge (Btw extended battery 2100mah) and by the time I wake up, it's completely dead.
    May I ask where you acquired your 2100mAh battery,
    as I have the same problem regarding lack of longevity of battery life.
    Thanks!
    P. S. - Can the Gnex be charged with a Qi charger?
    11-05-2012 09:05 PM
  16. Ridgerunner20's Avatar
    Hey urquattro83, you can get the extended battery that I'm using in my phone at amazon, here's the link Amazon.com: Samsung Galaxy Nexus (i515) Extended Battery with Battery Cover: Cell Phones & Accessories Also, I'm not sure if the galaxy nexus works with a Qi charger. Does anyone else here know if it does?
    urquattro83 likes this.
    11-05-2012 10:01 PM
  17. urquattro83's Avatar
    Thanks Ridgerunner, d I need a new battery cover or with the same one
    that covers my 1850 mAh battery cover the extended-life battery?
    11-06-2012 02:54 PM
  18. Ridgerunner20's Avatar
    You will need a new cover for the battery. The one I linked to amazon comes with a new back cover.
    11-06-2012 09:45 PM
43 12
