Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By jessesmith8888
    honex97's Avatar
    Posts
    Global Posts
    243 Global Posts
    Default Help with Verizon login client
    So I've been trying to use the NFL app for Verizon and it asked me to download the Verizon login client so on the market it says not compatible so I searched Google and found the apk on roozwiki so I've been trying to log into the NFL app and when it takes me to the Verizon login client I sign it and it always says service temporally unavailable and its been doing this for about a month.
    Right now I'm running cm10 on my nexus but its done this when I had stock ICS. Anyone have any advice?
    And also sometimes it will sign in and ask me to create a security question so I do and then it tries to load and says service temporarily unavailable again
  2. #2
    Default
    Here is the login client I used:
    It's working on bugless beast. You may also need the my Verizon app installed but Idk.
    Sent from the north woods
    Attached Thumbnails Attached Thumbnails Help with Verizon login client-uploadfromtaptalk1343379342449.jpg
    Thanked by 2:
    casper14209 likes this.
    honex97's Avatar
    Posts
    Global Posts
    243 Global Posts
    Default
    Thanks a lot. Its working now
    Thanked by:
  4. #4
    Default
    No problem! Last year I had to make sure the NFL app worked with thunderbolt roms before I'd flash them.
  5. #5
    Yung_Dilla's Avatar
    Posts
    Global Posts
    327 Global Posts
    ROM
    Vicious Jelly Bean
    Default Re: Help with Verizon login client
    My "my verizon" won't work it opens and when I go in on WiFi I get "services are temp unavailable" if no WiFi I get "a free Verizon connection is unavailable please try again later" I'm running vicious jellybean.
  6. #6
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    Arent they charging for the NFL this year? I gave up with my vz would like it to work just to watch the account.
  7. #7
    Default
    Quote Originally Posted by Yung_Dilla View Post
    Here is the updated my Verizon app.
    You may not see the update on some roms.
  8. Thread Author  Thread Author    #8
    honex97's Avatar
    Posts
    Global Posts
    243 Global Posts
    Default
    Quote Originally Posted by Xanth269 View Post
    Yeah Its $5 a month
  9. #9
    I've seen threads like this on many different forums and every single one ended with the op saying he gets service unavailable when logging into the login client. i am getting the same and haven't seen a single solution posted anywhere about it yet. anyone?
  10. #10
    ratedr79's Avatar
    Posts
    ROM
    Shiny 4.2.2
    When I last flashed, I had to uninstall the My Verizon app I had, and then use the files from this zip:
    VZWAPNLib and VZWAPNService had to be in system/app, and MyVerizon and VerizonSSO could be installed as normal apks. I had to then launch My Verizon, the old version, and it would work. Then I could update to the latest version. If I updated to the latest version before launching, I would get the unavailable message. Not sure if it'll work for you, but it did for me.
