- 08-10-2012, 01:24 PM
Thread Author #1
Anyone using the gnex without a case?
Just curious how many of you use a case / screen protector?
Sent from my Galaxy Nexus using Android Central Forums - 08-10-2012, 01:32 PM #2
- 08-10-2012, 01:39 PM #3
I use a screen protector only. I prefer looking at the phone the way Samsung intended.
Sent from my Galaxy Nexus using Android Central Forums“There’s always something to look at if you open your eyes!”
-The Doctor- - 08-10-2012, 02:12 PM #4
Re: Anyone using the gnex without a case?
i only use a case outside of my daily routines...as long as i am going to work, or staying at home i am running naked...any time i go on a trip, baseball game, working out, ect i slap my case on.
the only scratches i have are from my unusually tight fitting cheap chinese dock i got off ebay.
You know your rooted when bootloops don't scare you anymore. - 08-10-2012, 02:36 PM #5
I have been taking the case off of my Galaxy S II all day. I love the look and feel without the case. I probably wouldn't feel that way if it wasn't white.
- 08-10-2012, 03:32 PM #6
screen protection only. I haven't used cases since my HTC Evo days.
Sent from my Galaxy Nexus using Tapatalk 2 - 08-10-2012, 03:33 PM #7
No case, no screen protection, I just baby the device
Thanked by 2: - 08-10-2012, 04:35 PM #8
I prefer going without a case but ... I like to use a holster and when extracting from a holster you have to grip on the corners. The corners of the gnex are not designed to be gripped and I have dropped it so most of the time I use a tpu case.
- 08-10-2012, 04:45 PM #9
I use the ringke slim case, and you can't even tell that my phone has a case on. But, no screen protector here.
Sent from my jelly bean flavored nexus - 08-10-2012, 04:52 PM #10
Yeah I've gone naked since the day it came out. *giggidy*
I must've been lucky cuz one day I tripped on rough cement stairs slamming my GNex hard then it scraped across screen-down to prevent my fall...and it came away with only a very slight cosmetic scratch under the LED Notification light.
*PHEWF*
As long as my phones last a year, I'm good so for me personally I don't use cases.
Sent from my Galaxy Nexus using Android Central ForumsLast edited by Lanhoj; 08-16-2012 at 12:45 AM.
- 08-10-2012, 06:12 PM #11
I had a case for my Fascinate but the darn thing had crashes that called for battery pulls all the time. I got sick of taking the case off constantly so I got in the habit of going naked. Nothing happened to the phone after a year so when I finally talked Verizon into letting me upgrade early to the GN I decided it was too pretty to cover up.
- 08-10-2012, 06:47 PM #12
- 08-10-2012, 10:56 PM #13
- 08-11-2012, 12:06 AM #14
I've been using it without a case for a while but it got some scratches on the sides so will be using a case from now on
Sent from my Galaxy Nexus using Tapatalk 2 - 08-11-2012, 12:51 AM #15
I personally use a screen protector and a case. I do use a wet screen protector over the static ones. The wet ones are a bit harder to apply but you get virtually no air pockets and better clarity. I recommend XO Skins as they are the only ones that don't show an orange peel effect on the screen.
As for a case, I prefer to use a case that maintains the contour of the shape. So I use the casemate barely there case.
Sent from my Google Galaxy Nexus using Tapatalk 2Samsung Galaxy Nexus
CM10 Jellybro Jelly Bean
Asus Nexus 7
AOKP JB Milestone 1 - 08-11-2012, 01:06 AM #16
I use the incipio case Verizon sells in their stores. It is nice and doesn't add much bulk and it can fit the phone with the extended battery on. Sure the edges aren't flushed on each corner but honestly it's pretty close. I have 3 other cases but this is my fav.
- 08-11-2012, 01:10 AM #17
- 08-11-2012, 01:21 AM #18
- 08-11-2012, 04:00 PM #19
I've had mine naked since day one. My screen has on minor scratch and there's a tiny nick on the corner from when I dropped it, but it's not enough to bother me or make me want to put it in a case.
Sent from my Galaxy Nexus using Tapatalk 2 - 08-11-2012, 04:11 PM #20
- 08-12-2012, 07:27 AM #21
- 08-12-2012, 11:25 AM #22
No case here. When pulling it out of my pocket, I've gotten into the habit of pinching it firmly front to back instead of edge to edge. So I get some fingerprints on it, but it's less likely to twist and slip its way free of my grip.
TJH
Sent from my Xoom using Tapatalk 2 - 08-12-2012, 12:52 PM #23
- 08-12-2012, 01:11 PM #24
I always go naked with my devices...
- 08-13-2012, 05:54 AM #25
No case. I use a "BestSkinsEver" wet skin. I jump from dock to dock to dock, so it would be maddening to use a case.
My phones have been caseless since '08.
If you have dogs, crazy kids, or are drop prone, it wouldn't hurt to have one. Mine's usally in a dock, or in my pocket, so I'm not that worried.
Reply
