Results 1 to 3 of 3
- 08-14-2012, 05:22 AM
Thread Author #1
VERY WEAK (If any) 3G signal after digitizer replacement
I dropped my GNex and broke the glass. Unfortunately, the whole screen assembly had to be replaced. Verizon wouldn't do it so I decided to replace it myself. It was relatively easy & only took about 40 min. The phone booted right up and everything including WiFi, 4G & Bluetooth are working, except for 3G. I thought maybe I damaged the antenna wire so I also replaced that but still no signal. Under "About Phone" I noticed there is no PRL or MDN version. Replaced the SIM card, but that didn't help. Has anyone ever heard of this happening or have a solution to this? I've looked all over the place and have found others that this has happened to but nobody has posted a solution. Thanks!
- 08-15-2012, 08:12 AM #2
Re: VERY WEAK (If any) 3G signal after digitizer replacement
I've heard of all sorts of horror stories prior to self servicing Android phones. I'd personally never do it, I'd rather spend the $100 on my insurance deductible.
“Around here, however, we don't look backwards for very long.
We keep moving forward, opening up new doors and doing new things,
because we're curious...and curiosity keeps leading us down new paths.”
-Walt Disney - 02-07-2013, 08:00 PM #3
Reply
