Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By garreffster
    Default how much faster does the Galaxy Nexus die if I leave hotspot on?
    how much faster does the Galaxy Nexus die if I leave hotspot on at all times?
  2. #2
    Default
    Unplugged it will only go for a few hours tops under constant use. You may get three full hours. More like two. I plug mine in when using it as a modem.
  3. #3
    Default Re: how much faster does the Galaxy Nexus die if I leave hotspot
    It will die precisely 2 hours, 17 minutes, 35 seconds, and 8 milliseconds faster than with hotspot off.
    Thanked by:
    saichick04 likes this.
  4. #4
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by garreffster View Post
    Lol
    Sent from my Nexus 7
  5. #5
    Murph5150's Avatar
    Posts
    ROM
    Euroskank CM10
    Default
    It definitely drains quickly. I use mine almost daily and it can consume 20% of my battery on my lunch break.
    Pure mathematics is the only truth in our world.
  6. #6
    Default
    I use Bluetooth to tether my N7. Doesn't drain as fast as actually being used with the screen on.
  7. #7
    Default
    Quote Originally Posted by jova33 View Post
    How are the speeds using Bluetooth versus wifi hotspot, assuming a good LTE signal?
  8. #8
    Default
    Just tested, and I think Wi-Fi might be better. Bluetooth, I dunno, acting funny
