Results 1 to 7 of 7
Like Tree1Likes
  • 2 Post By MalachyNG
    MalachyNG's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How I fixed my wifi speed
    Hey all,
    I've had my Verizon Galaxy Nexus for about a week now and noticed that it (as well as my Nexus 7 I've had since July) were getting really cruddy wifi speeds. I was getting fed up with it and started searching for solutions. There are a few threads kicking around the net about GN's having bad wifi reception or poor speed. Most of the answers have been along the lines of bad router or bad wifi chip in the phone. But none had any definitive fix that I could find. I am making this thread in hopes that others might find success same as I have.
    The solution, for me, was to change my wifi router settings so that it is on channel 11 and network mode "wireless-b, only" (rather than n, g or auto).
    Here's an article on how to change your router settings if you happen to have a linksys router like I do:
    Change Your Wi-Fi Router Channel to Optimize Your Wireless Signal - How-To Geek
    My solution was found through dumb luck. I freely admit that my knowledge on the hows and whys is lacking but it seems that after testing every channel I was still getting really poor speedtest.net results on my phone (I pay for 20mbps down from Comcast and my laptop gets 17-20 on average regardless of these settings). I chose to change the network mode to "wireless-b, only" because I was trying to see what else might work. I chose channel 11 because I live in a large apartment complex and channels 1-6 were pretty crowded whereas 8-11 weren't. It seems the main difference for me was switching to wireless-b. Now my galaxy nexus is downloading at 19mbps consistently, youtube videos don't stop to buffer anymore and flash on newgrounds.com loads in seconds.
    I hope this helps others. Cheers!
    Eric_L_1 and KG II like this.
  2. #2
    Small_law's Avatar
    Posts
    Global Posts
    622 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How I fixed my wifi speed
    Switching to channel 11 probably helped the most. The b radio connection speed from the phone to the router transmits at a slower rate than g (54 mbps) or n (300 mpbs or more with channel bonding). The Nexus seems to top out at 65 mbps. Try n again with channel 11.
    MalachyNG's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Channel 11 on N was still bad. Perhaps I misstyped. "Varied G/B" also gives a good speed (19mbps). But anything on N is slow (1.5mbps). "B, only" also gives me 19mbps, even though as far as I know, the b standard is only supposed to run at 10mbps
  4. #4
    rufflez's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can change your QoS (quality of service) in your router settings giving priority to your phone. That worked like a champ for me. You register your device's MAC address and give it a priority of 1.
    MalachyNG's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rufflez View Post
    I had already done that too. Both my nexus 7 and galaxy nexus were already set as high priority. Perhaps a mix if all these settings did the trick. Oddly enough it was changing to B and B/G that actually made any difference for me
  6. #6
    dookie.'s Avatar
    Posts
    Global Posts
    278 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unless the router is routinely at capacity, this should make no difference... not saying it didn't, but if I saw this on an idle router, I'd be looking for firmware updates or a new one.
  7. #7
    Eric_L_1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FO SHIZZLE
    YOU'RE A GENIUS
    THANKS TO YOU
    THE BOYS ARE BACK IN TOWN!
    CHEERS INDEED!!!
    YOU JUST MADE ME CRY, BROTHER
  1. I fixed my wifi connection problem
    By dj2big in forum Sprint Nexus S 4G
    Last Post: 06-07-2012, 02:01 AM
  2. [HOW TO] Fix my verizon mobile app error 305
    By danalo1979 in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 07-09-2011, 02:39 AM
  3. Replies: 0
    Last Post: 06-09-2011, 08:54 PM
  4. How I fixed my Nexus S back LED
    By Smokexz in forum T-Mobile Nexus S
    Last Post: 04-24-2011, 01:58 PM
  5. Fixed my wifi, maybe this fix can help you
    By craig928 in forum Verizon Droid Incredible
    Last Post: 04-30-2010, 03:39 AM
