Results 1 to 14 of 14
    Default Gps wont lock on
    Proud to say I just got my update to 4.1.1 and I had this problem before were my GPS won't lock it takes any were from 3 to 10 min to finally lock on. I tried the quick fix option they had for the GSM version bit did not work. Anyone know how to fix this? Without rooting. Thanks.
  2. #2
    Default Re: Gps wont lock on
    I think it has something to do with the Maps update. I'm still on 4.0.4 and yesterday it would not lock in when I used Maps on 3G. When I got to an LTE area and the radio switched, it locked in.
    Quote Originally Posted by Small_law View Post
    Hmmm I will have to try that out. Thank you.
    I tried it and had no luck.... if I can fix this problem the update so far is solid and I'll keep the phone. Haha
  5. #5
    Nechasin's Avatar
    Posts
    ROM
    Something new!
    Try this. Go into settings, Location Services, and uncheck Google's Location service and recheck it. I know this has been a problem on a lot of the roms that I've used since JB came out and that fixed it.
    OK I will go and try that. Thank you.
    Tried that as well and still no luck......
  8. #8
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by slik6996 View Post
    Try a new gapps package if you're on a rom.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  9. #9
    Did you try turning off your phone removing battery and Sims
    Sent from my SCH-I535 using Android Central Forums
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by smbrooks32 View Post
    Nope have not tried that but I will thank you.
    ---------- Post Merged at 06:55 AM ---------- Previous Post was at 06:55 AM ----------
    Quote Originally Posted by dmmarck View Post
    Nope I'm stock. Guess I might be screwed......
  11. #11
    do you have wifi at home? do you use it? is your router registered in google's databases? not sure about JB, but with GB i had an issue where i couldn't lock on until i connected to a google-known router. i guess the device relied on that location information in order to "zero in" to satellites or something.
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by dahlheim View Post
    Yes I have and use wifi but even in LTE and 3g mode it won't lock.
  13. #13
    i don't think you read my questions. is your router registered in google's databases? i'm not asking because i think it's related to your wifi. i'm asking because sometimes it appears google devices use recent wifi connections to find appropriate satellites for your area.
  14. Thread Author  Thread Author    #14
    I don't think it is I use my schools wifi in my dorm room. But how would that also make it not lock on in LTE and 3g as well?
    ---------- Post Merged at 07:00 PM ---------- Previous Post was at 07:00 PM ----------
    ---------- Post Merged at 07:02 PM ---------- Previous Post was at 07:00 PM ----------
    I don't think it is I use my schools wifi in my dorm. But that should have any effect on LTE or 3g but it woont lock on those either. Idk what else to do.
    ---------- Post Merged at 07:03 PM ---------- Previous Post was at 07:00 PM ----------
    I use my dorm room wifi at school so I doubt it. But it also don't lock on 4g or 3g either?
  1. Screen wont lock after timeout, stays on
    By tomme12 in forum Sprint Epic 4G
    Last Post: 01-06-2011, 06:55 PM
  2. No lock on the GPS
    By smurph#ac in forum AT&T Captivate
    Last Post: 07-28-2010, 03:27 PM
  3. no gps lock-on
    By terpitude71 in forum Motorola Droid
    Last Post: 05-10-2010, 06:31 PM
  4. GPS won't lock on (MileStone)
    By HaydenT in forum Motorola Droid
    Last Post: 03-05-2010, 07:17 PM
  5. GPS Lock-on problem
    By RichR in forum Motorola Droid
    Last Post: 11-15-2009, 05:44 PM
