Results 1 to 7 of 7
- 09-23-2012, 08:48 PM
Thread Author #1
Not charging while powered on?
My phone won't charge at all while its turned on I've tried different cables different bricks and have plugged it into my computer but still no go. But, when I turn it off it apparently is charging..
Sent from my Galaxy Nexus using Android Central Forumsnothing nothing nothing - 09-23-2012, 09:04 PM
Thread Author #2
Re: Not charging while powered on?
Okay so I did a battery pull and when I booted up it was at 54% when I did the pull it was at 10% also notice how it says "not charging" instead of discharging and notice the sudden drop and then rise
Sent from my Galaxy Nexus using Tapatalk 2nothing nothing nothing - 12-23-2012, 09:18 AM #3
I've just started having this charging issue too, when previously the past 12 months I haven't. It only charges when it's off. And when it's on, the battery drains like crazy when previously I've had no problems.
Samsung Galaxy Nexus (Dec. 2011)
Previously: Droid X (July 2010) - Blackberry Tour 9630 (July 2009) - Dumbphones (pre-July 2009) - 12-23-2012, 09:45 PM #4
- 12-23-2012, 11:08 PM #5
Same issue here but has since went away. Mine started acting up when I got some water in the charging port. Once the water dried away I guess, it started working fine again.
- 12-24-2012, 01:29 AM #6
I read around that the usb pin inside the charging port can be bent the wrong way. Use a toothpick to bend that pin more towards the screen and you should be good to go. I don't know how that makes it work technically, but it worked for me. Phone is now charging while on, and says "Charging (USB)" when I have it plugged in.
Previously: Droid X (July 2010) - Blackberry Tour 9630 (July 2009) - Dumbphones (pre-July 2009) - 12-28-2012, 03:57 PM #7
Many thanks guys!!! the last one worked fine for me... just a little push the inside pin (the one with the cupper contacts) with a plastic stick and carefully. It actually works as it did till yesterday night, thanks again community, it was a great headache for many hours (I was even searching for replacement parts and reading workarounds even worst).
Regards.
phone is plugged in but not charging. light is on
By GoTTi in forum HTC EVO 3DReplies: 20Last Post: 05-17-2013, 01:16 AM -
Htc sensation will not charge or turn on but orange led flashes..
By JimiVaughanDrix in forum IntroductionsReplies: 2Last Post: 05-16-2012, 01:10 PM -
Charging while off on CM7?
By Supakitsune in forum LG Optimus S Rooting, ROMs, and HacksReplies: 3Last Post: 07-30-2011, 09:22 AM -
[Mod] Samsung Boot Logo Mod (Not bootanimation, SAMSUNG power on logo)
By wyllic in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 36Last Post: 03-31-2011, 10:53 PM -
when i try to charge while powered off, clockwork starts automatically
By theartialmartist in forum Software Development and HackingReplies: 0Last Post: 08-16-2010, 09:38 PM
Reply
