Results 1 to 8 of 8
    Unhappy after jellybean, My voice commands are broken, My Girlfriends gnex voice commands work fine, help?
    So if i say, for instance
    "Navigate to chevron" - it performs a google search, instead of navigating.
    if i say "call domino's" - oh look. a google search. that's helpful.
    if i say "what's the weather like?" i get "the weather in denver, colorado is whatever" cool. I live in utah. (if i turn on wifi this one seems to work. but still, what gives?)
    before jellybean, google search performed these actions, no problem. in addition, my girlfriends gnex does all this just fine. Can someone please help me? i use to use this all the time so i didn't have to type while driving!
  2. Thread Author  Thread Author    #2
    Default Re: after jellybean, My voice commands are broken, My Girlfriends gnex voice commands work fine, hel
    no help? does no one have these issues?
    ---------- Post Merged at 09:05 PM ---------- Previous Post was at 08:59 PM ----------
    *semi fix*
    if i open maps or something and let it find my general gps location. it works fine. can it not use an approximation? the weather tile uses a good approximation. but when i ask for weather without kicking up maps first, it gives me colorado. so bizzare.
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by harleyb16 View Post
    For navigation, I use "take me to [insert location here]." Works fine. After the "count down" it opens up Navigation.
    For the rest, I haven't used it for that.
    Thanked by:
  4. #4
    Test your GPS... also clearing data in Google search then rebooting phone is said to fix problems like this
  5. #5
    Thanks for that tip, it works perfectly!
    ---------- Post Merged at 01:14 PM ---------- Previous Post was at 01:13 PM ----------
    Quote Originally Posted by dmmarck View Post
  6. #6
    I had to uninstall Google Search and everything worked great!
  7. #7
    Angry Re: after jellybean, My voice commands are broken, My Girlfriends gnex voice commands work fine, hel
    Uninstalling Google Search, trying "Take Me to <contact name", uninstalling Map updates all didn't work. Any other advise to try?
  8. #8
    I was having this problem as well on my gnex4 phone, then I Updated the google search app and everything started working as expected again. good luck.
  1. Please advise, my calendar entries are gone after ICS
    By razr maxximus in forum Droid RAZR MAXX
    Last Post: 04-13-2013, 11:12 PM
  2. Can't use my apps that are on my SD card for my Samsung Charge
    By eL Dawgo in forum Verizon Droid Charge
    Last Post: 02-26-2012, 08:49 PM
  3. Using Google Voice visual VM with my regular verizon #?
    By ctychick in forum Verizon Droid Incredible
    Last Post: 09-03-2010, 12:01 AM
  4. Where are all my HTC widgits from 1.5? :(
    By NickF227 in forum HTC Droid Eris
    Last Post: 05-18-2010, 09:19 AM
  5. Forgive my ignorance but are these the same phone?
    By jamesedward318 in forum Verizon Droid Incredible
    Last Post: 04-12-2010, 01:28 AM
