Results 1 to 10 of 10
    dugsurf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Jellybean nexus battery assassin
    Although I appreciate the improved operation of my Verizon G Nexus on Jellybean, I'm shocked at the accelerated rate of battery depletion it brings. I am now loosing about five percent charge every 10 minutes. This is on the lowest screen brightness setting with wifi, gps, bluetooth, and 4G turned off. Any Suggestions?
  2. #2
    trunks527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Jellybean nexus battery assassin
    Quote Originally Posted by dugsurf View Post
    Try turning off GPS and location services. I noticed maps started eating my battery without it ever happening on ics. As always pull battery and reboot. I last about 12 hours with auto brightness and 4G on all the time.
  3. #3
    jephanie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was suffering significantly poor battery life, too. I was lucky to get 6 hours out of a full charge. I did a factory reset and BOOM, I am getting over 12 hours of life with over 2-1/2 hours of screen time and 45 minutes of gaming. I am now a very happy camper. The reset definitely took care of some odd behavior as well (e.g. "Media" was sucking more juice than the screen was).
    So try a factory reset and get a fresh start on the install of JB. It certainly helped me!
    dajobo likes this.
  4. #4
    sisblub's Avatar
    Posts
    Global Posts
    309 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yea same here, actually for the first week after the JB upgrade I was getting about the same battery life, 12-16 hrs depending on use and about 2 hours screen time, but now I can hardly get an hour of screen on time and my battery life sucks. Any ideas?
  5. #5
    Armada's Avatar
    Posts
    Global Posts
    299 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you don't use any features of Google Now, turn it off. The fancy voice search is still there if the Now features aren't on, thankfully. I noticed a pretty big savings in battery life.
  6. #6
    BBwhat's Avatar
    Posts
    Global Posts
    23 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, Google Now is the culprit. Any feature selected continually updates and uses lots of battery. I turned it off and battery life returned to normal.
  7. #7
    dajobo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jephanie View Post
    I just did this last night. Hope it will help! I will report in the next few days!
  8. #8
    dcastillo's Avatar
    Posts
    Global Posts
    500 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Factory reset always helps battery life, more then almost anything else....
    Im tempted to do it on mine as well... might hold out for a few months till the next SW update is about to hit... that way I have a fresh start....
  9. #9
    roadrat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How do you turn off G Now?
  10. #10
    jephanie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by roadrat View Post
    Access Google Now by swiping up. Tap the three dot thingy, choose Settings, tap Goggle Now, tap the On/Off selector and you're done.
  1. Nexus Battery life... Face Lock???
    By Clancy3434 in forum Google / Samsung Galaxy Nexus
    Last Post: 12-26-2011, 06:36 PM
  2. nexus battery cover
    By panitsos in forum Verizon Galaxy Nexus
    Last Post: 12-22-2011, 10:03 AM
  3. AT&T Galaxy Nexus - Battery Life?
    By scottder in forum Google / Samsung Galaxy Nexus
    Last Post: 12-19-2011, 10:07 PM
  4. Words with friends = battery assassin??
    By Herk_FE in forum LG Optimus S
    Last Post: 12-09-2011, 09:11 PM
  5. Galaxy Nexus Battery Review...?
    By Rickgsx in forum Verizon Galaxy Nexus
    Last Post: 11-24-2011, 07:53 PM
