Results 1 to 7 of 7
    Default GPS Signal Problems
    I've been using the Google Navigation recently and each and every time (tried it about 5 times), with varying weather each time (from rainy and cloudy to perfectly clear) it takes my phone a solid 5 full minutes to lock on to a GPS signal. Is this common? If not, is there anything that can be done to speed it up?
    Honestly, at 5 minutes to wait, its completely not even worth using Navigation.
  2. #2
    Default Re: GPS Signal Problems
    Not normal... mine locks in less then 30 seconds every time...
    sent from a Nexus, nothing less will do...
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by reykjavik View Post
    Have you tried clearing the cache from Maps?
    Sent from my Overly Suspicious Robotic Grouper
    No, I didn't. Is that a common fix?
  5. #5
    Whenever I've had that problem a simple reboot did the trick.
    FWIW- I had problems with data connection just the other day and rebooting fixed it.
  6. #6
    I had this problem when I was running an early JB rom. Are you stock or running a ROM of some sort?
    Quote Originally Posted by jamontoast1291 View Post
    Complete stock. Never rom'ed. Waited for vzw update like a good boy. I actually think the cache clearing did the trick.
  1. LG Ally- GPS Location problems
    By bleacher in forum LG Ally
    Last Post: 07-15-2011, 06:55 AM
  2. Stuck GPS signal
    By captain#ac in forum General Help and How To
    Last Post: 09-01-2010, 03:10 PM
  3. Samsung vibrant signal problems????
    By livinlife in forum T-Mobile Vibrant
    Last Post: 08-03-2010, 01:03 PM
  4. Signal Problems??
    By CynicalDreams81 in forum Motorola Droid
    Last Post: 07-24-2010, 03:06 AM
  5. LG Ally- GPS Location problems
    By bleacher in forum Misc. Android Phone Chat
    Last Post: 07-04-2010, 10:06 AM
