Results 1 to 4 of 4
    Default Extended battery worth it?
    Hi, Iwas thinking about purchasing the eextended battery, they are only like 30 bucks. But is buying it worth it. I have to charge mine about twice a day. I listen to music and would say I use it moderate to heavy amount. So if I get this battery will it make it throughout the whole day or will I be disappointed with the 30$ bucks I dropped on it?
  2. #2
    Default Re: Extended battery worth it?
    If you charge twice a day now... then no.... the extended battery won't make it through the day....
    Its only about 15% larger
    sent from a Nexus, nothing less will do...
  3. #3
    I got the mammoth Hyperion battery 3800mAh from Amazon for $20 plus shipping. I only use it on weekends, as during the week I am always near a charger so I use the stock battery. The back cover is pretty cheap and mine does not lock in properly all the time but for the price I won't complain. Personally I did not seeing the 2200mAh worth it for me.
  4. #4
    gregs1213's Avatar
    Posts
    Global Posts
    275 Global Posts
    Carrier
    AOKP (M5) Franco (M4)
    It's not worth it in the sense that's it only slightly larger.. It may be worth it as a backup battery. I keep a spare battery in my wallet at all times, since my nexus gets HORRIBLE battery life. You can get something like this:
    2X 1980mAh Battery Charger for Verizon Samsung Galaxy Nexus i515 SCH I515 | eBay
    but honestly, those batteries suck, and will not last for very long, but it's probably worth it just for the battery charger. I like to just be able to swap batteries instead of being tethered to a wall.
  1. Replies: 11
    Last Post: 08-17-2012, 09:48 PM
  2. Is the extended battery for the Galaxy Nexus worth it?
    By Anndrew Vacca in forum Verizon Galaxy Nexus Accessories
    Last Post: 05-13-2012, 01:06 PM
  3. Is the 2150 extended battery worth it?
    By kilofoxtrot in forum Verizon Galaxy Nexus Accessories
    Last Post: 01-17-2012, 01:37 PM
  4. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
  5. Is the 2150 extended battery worth it?
    By in forum Verizon Galaxy Nexus
