Results 1 to 8 of 8
- 11-26-2012, 01:04 PM
Thread Author #1
- 11-26-2012, 04:42 PM #2
Re: Rom for best battery life
I don't think your ROM has anything to do with it. I have to airplane mode my phone at work because of weak signal. I've run multiple ROMs and there isn't a better than another out there. Bottom line is that the battery on this phone sucks.
Sent from my Galaxy Nexus using Android Central ForumsPure mathematics is the only truth in our world. - 11-26-2012, 04:53 PM #3
Kernel and kernel settings are going to have more effect on battery life.. the ROM has little to no effect, really.
EDIT: as well as the usual factors like signal strength, etc...
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI - 11-27-2012, 12:16 AM #4
Going off of what 2def said, the following things will be your best friend when you need longer battery life:
CPU clock speed (underclocking)
CPU voltage (undervolting)
Signal management (LTE toggle, Airplane mode)
Fewer clock cycles per second mean less power used, a lower voltage level means less power used per clock cycle and smart signal management is simply the most efficient method of power conservation for LTE-enabled devices.Represent yourself well; you never know what might happen. And try out the new Android Central app!
Softbricking be damned. - 11-27-2012, 12:18 AM #5
+1,000 on the kernel... Its the life line to everything and key to battery management
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
Thanked by 2: - 11-27-2012, 10:48 AM #6
I have a few things to say about this topic.
1st, i have had pretty good experiences with AOKP M1 build....the last AOKP 4.1.2. i flashed it last night and TRIED to kill my battery (trying to diagnose my terrible battery life on 4.2) and i couldn't do it in 6 hours. i made a 30 minute call, took some photosphere pics (4.2 transformation pack) lots of forum browsing, messaging ect. before i went to bed i was at 7 hours and 24% left with 1 hr 32 minutes screen on time. it was pretty solid for me.
2nd. there are LOTS of things that can effect battery life.
the main one is apps. when you are on the "cutting edge" of operating systems, some apps get forgotten about and dont get updated to work with your current OS. i had an app that would literally keep the phone clocked at 700 mhz all day long and suck my battery dry in a couple hours. once deleted, battery life bounced back. as long as you are rooted, it is fairly easy to pinpoint a problematic app. use "better battery stats" from the play store or XDA and check your partial wakelocks. there shouldn't be much in there above 2% unless you stream music. if there is, that is your problem app.
also check out "cpu spy" from the play store. make sure your phone is going into deep sleep. if not, there is an app keeping it awake or the kernal should be switched out.
signal, if you have terrible signal, that really chews through battery as well.
Kernel, yes, some kernels play better than others, but most of the time they all act pretty similar. but some do "deep sleep" better than others.You know your rooted when bootloops don't scare you anymore. - 11-27-2012, 02:08 PM #7
- 11-30-2012, 08:16 AM #8
There are two things that will give you longer battery life, 1) a WiFI connection, 2) a 3800ma battery. WiFI uses a lot less power than LTE so you should make sure you have a WiFI connection at home and at your office if possible. 2) There are a number of 3800ma batteries available for the Galaxy Nexus, I have both the Hyperion and the Trexcell, they look like they are really from the same manufacturer so you can buy either. The 3800ma batteries are available on Amazon for around $20.
Rom/kernel combo for the best battery life
By auburngirl in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 2Last Post: 05-28-2012, 02:49 PM -
Best rom for best Battery power
By joeb727 in forum T-Mobile HTC SensationReplies: 0Last Post: 04-07-2012, 05:23 PM -
ROMs for longest battery life?
By O13 in forum Optimus V Rooting, ROMs, and HacksReplies: 29Last Post: 03-21-2012, 10:46 PM -
rom/kernel combo for best battery life
By daygo619 in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 4Last Post: 01-05-2012, 02:46 PM -
Best rom for perf/battery life?
By bocaccio in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 8Last Post: 05-10-2011, 04:20 PM
Reply
