Results 1 to 9 of 9
    Default Galaxy nexus stop charging will Verizon send me a new unit.
    hi, my nexus just started not charging unless you place and hold the charger in a certain way. I sitlll have the warranty on it(it is ending on the 15th so thank god the phone stated acting up now. The only thing worrying me is that i have a cracked screen. and in the warranty i believe it states it does not cover cracked screens so i am very worried that they will not want to send me another unit because my screen is cracked even though its charging port has nothing to do with the screen, if you were in my position what would you tell the Verizon employees and can someone please post links on how to revert back to stock and lock my bootloader so i can do it before i got to the store.
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: Galaxy nexus stop charging will Verizon send me a new unit.
    they are going to charge you one way or another for the screen.
  3. #3
    There are two reasons why this charging issue can show up. The first is that the contacts in your microUSB charger have been damaged in some way -- you'll need to try a different charging cable to figure this out. The second possibility is that the pins inside your phone's microUSB port have been damaged. This is the case if all charging cables fail to work correctly.
    If your phone's microUSB port is damaged, you can try making sure that the pins aren't bent out of place. Otherwise, you'll probably have to get a replacement.
    Represent yourself well; you never know what might happen. And try out the new Android Central app!
    Softbricking be damned.
    Quote Originally Posted by Lumenii View Post
    yes, i alreaqdy know the issues it is the phone. i have many chargers and they all fail to work on it unless theyre placed in a certain way. I already tried bending it back and it worked for a little bit but started having the issue again. my question was how would i approach a verizon employee and convince em to send me another one even thought the screen is cracked. I used to have a friend that worked at verizon and last time he managed to send me a new phone under warranty even though the only problem with the phone was i had cracked the display. He no longer works there and im worried im not gonna get i my way this time
  5. #5
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Your not. They are going to try to charge you for the screen. You never know though and could get lucky, though I would bet against it.
    Sent from my X-Band Modem... TY Genesis
  6. #6
    It certainly isn't impossible, but it is unlikely. You'll have to convince them that the problem is the result of some sort of manufacturer oversight or defect. Typically, a manufacturer's warranty will cover defective USB ports, however yours has been functioning just fine for an extended period of time. The condition of your screen will indicate that the microUSB damages are most likely the result of a warranty-voiding standard of care.
    That's how it will come across. I can't tell you how to 'convince' the Verizon employee that the microUSB damage falls under the warranty; you just have to be honest and try to convey that the port damage occurred by no fault of yours.
  7. #7
    reddtessa's Avatar
    Posts
    Global Posts
    4 Global Posts
    ROM
    Stock
    They won't help you with the cracked screen as its not covered under warrenty, unless you get that fixed outside of Verizon.
    My charge port went out and my screen was cracked, when they said that if there was physical damage to the phone when it was received I'd have to pay for the replacement phone. I then said nm I'll just get an external charger and deal with it. Then Android 4.1.1 came out, my phone didn't like the update so was constantly getting the dreadful bootloop at the logo. I even went into the VZW store trying to get them to at least get me out of a bootloop, they did go ahead and try helping me even though they said they really weren't allowed too. Nothing worked so they called up Sammy as it was then their problem since it was the update, well Sammy said before they could even touch it I'd have to pay and get the screen replaced which all in all wasn't that bad a tad under $165 and the headache of reinstall everything when it was returned.
    So your best bet replace your screen with Samsung (they might even fix your charge port) or replace your phone with an ebay one (which is what I ended up doing after think it over for a day either 165.00 and risk more problems or 200-220.00 and a like new nexus), as I don't think it'll go the way your hoping.
  8. #8
    Quote Originally Posted by xxmariolxx View Post
    I had this problem too. I did a warranty replacement and was charged because the charging port was corroded (I didn't open it up to look before I sent it in and have no idea why it would be, but it was a three hundred dollar charge).
    Sent from my Droid DNA
  9. #9
  1. Replies: 17
    Last Post: 01-11-2012, 01:59 PM
  2. Replies: 12
    Last Post: 03-17-2011, 05:13 PM
  3. Replies: 19
    Last Post: 01-05-2011, 07:19 PM
  4. Verizon sending me 2 X's
    By DThomp in forum Motorola Droid X
    Last Post: 07-19-2010, 08:53 AM
  5. What is Verizon sending me???
    By sumner929 in forum Verizon Droid Incredible
    Last Post: 05-26-2010, 08:36 AM
