Results 1 to 21 of 21
    Default Slim 2800mAh battery
    Got one of these non-nfc batteries from amazon. We'll see if they last any longer than my 2100mAh ones!
    oops wrong section, please move
  2. #2
    gregs1213's Avatar
    Posts
    Global Posts
    236 Global Posts
    ROM
    AOKP (M5) Franco (M4)
    Default Re: Slim 2800mAh battery
    Link? Are these more compacted batteries?
  3. #3
    Jaredshoes's Avatar
    Posts
    ROM
    AOKP
    tell me more tell me more, I would shell out some money for a slim 2800
    nothing nothing nothing
  4. #4
    bigdaddytee's Avatar
    Posts
    ROM
    Stock
    Just got a 3800 and I'm loving it...are there cases for the 2800?
    Sent from the red headed stepchild of the Nexii.
  5. #5
    These fit with standard battery door? Please keep us posted. Chances are they aren't any better but you never know!
  6. #6
    Hot94Z28's Avatar
    Posts
    Global Posts
    327 Global Posts
    I would like to know also. The 2100 is just not enough.
  7. #7
  8. Thread Author  Thread Author    #8
    I am on day 3. The first two days weren't any good, but today is good.
    It's not available but it was $11 after shipping and its slightly slimmer than oem, go figure.
  9. #9
    Hot94Z28's Avatar
    Posts
    Global Posts
    327 Global Posts
    Did you have an extended battery before this one to compare?
  10. #10
    gregs1213's Avatar
    Posts
    Global Posts
    236 Global Posts
    ROM
    I doubt these would last longer than an 1800 mah battery.. Your stats don't look that good.. Screen is only 15% usage and you are at 12 hours..
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by gregs1213 View Post
    Yeah, you didn't see what it used look like, I wouldn't make it before sundown
  12. #12
    gregs1213's Avatar
    Posts
    Global Posts
    236 Global Posts
    ROM
    I know how it is.. I think I am pretty notorious for talking about how bad the battery on this phone is... I seriously think I could use it all in less than an hour.. I'm usually about close to 50-60% after 5 hours of leaving the house and I don't even touch it.. I really can't believe people somehow get 16 hours with 2 hours on screen time.
  13. #13
    Nakrohtap's Avatar
    Posts
    ROM
    CM10.1 Fitsnugly AOKP
    2 hours of screen on time should be easy if you are not playing Angry Birds or some other game that sucks the battery life from your phone. The kernel makes a big difference as well. I installed a kernel yesterday that turned out to be a bad build. I lost 30% in 2 hours simply because it wouldn't go into deep sleep.
  14. #14
    gregs1213's Avatar
    Posts
    Global Posts
    236 Global Posts
    ROM
    Quote Originally Posted by Nakrohtap View Post
    Flashed every kernal/rom combo, nothing helps.. I might be able to play Angry Birds for one straight hour..
    I'll do an experiment right now.. I'm on Liquid Smooth 4.2.1...We'll see how long it takes to drain my battery, I'll keep the screen on 20% brightness or so, and put on something not very intensive.. maybe just keep it on the home screen.
  15. #15
    turdbogls's Avatar
    Posts
    Global Posts
    364 Global Posts
    ROM
    changes all the time
    i see a "terrible screen burn in" thread in your near future
    in all seriousness, i am getting around 3 hours screen on time on wifi, and about 2 on LTE. this is on CM10.1 with the included kernel. wifi, BT, GPS off, Maps app is disabled until i need to use it. and with that set up, i am golden for all day use.
    You know your rooted when bootloops don't scare you anymore.
  16. #16
    Quote Originally Posted by turdbogls View Post
    I get that on stock, GPS on.
  17. #17
    turdbogls's Avatar
    Posts
    Global Posts
    364 Global Posts
    ROM
    Quote Originally Posted by Pollster View Post
  18. #18
    Grinch
  19. #19
    Posts
    ROM
    Stock
    Suck it up, and ShopAndroid for the Seidio 3800. I went from 2-2.5 hrs screen on time to almost 5.
    Money well spent.
  20. #20
    Lightbulb Re: Slim 2800mAh battery
    Okay, I looked into this. It's really a 2200mah battery. Look at the picture of the battery on Amazon and it clearly says 2200mah. Look at the description of the battery from the manufacturer and it clearly says 2200mah.
    The 2800mah header for product at Amazon is clearly a typo.
    Nothing to see here people, move along.
  21. Thread Author  Thread Author    #21
    Quote Originally Posted by AndroidRobot View Post
    They changed the picture and stopped selling the 2800 and forgot to change the heading of the listing after the change. However, I ordered it when it was 2800 and my battery says 2800 on it.
    Anyway to test it?
  1. Official Shop Baixt Slim Extended Battery 2800mah for Samsung Galaxy Nexus
    By sob372 in forum Verizon Galaxy Nexus Accessories
    Last Post: 04-01-2013, 10:17 PM
  2. Seidio Innocell slim extended battery
    By ellisz in forum Fascinate Accessories
    Last Post: 12-30-2010, 09:47 PM
  3. Seidio 1600mah Slim Extended Battery
    By Ricey20 in forum Epic 4G Accessories
    Last Post: 12-02-2010, 12:00 AM
  4. Replies: 0
    Last Post: 11-05-2010, 04:34 PM
  5. WTS: Seidio Innocase Surface With Holster Combo PLUS Innocell 1750 Slim Ext. Battery
    By DougFNJ in forum Sold / Archived Marketplace Threads
    Last Post: 07-07-2010, 09:11 AM
