1. Aguaski's Avatar
    For Christmas I am finally making a much needed upgrade to the stereo deck in my car. Gone are the days of using my GNex to listen to music through a cassette adapter. My new deck will have a 3.5mm aux in and a high powered USB charging connector. The location of the charging connector is very close to where I doc my phone. With that said I would like to find a short micro USB cable that is suitable for charging. My definition of short is approximately 12 inches. Most of the USB cables I am finding that can charge at the faster rate are 36-48 inches. Does anyone have a lead on a good quality 12 inch USB cable that is capable of high speed charging.
    FYI - My purpose for wanting a short cable is to avoid the messy look of the excess I will have with the longer cables.
    12-19-2012 04:33 PM
  2. yosteve's Avatar
    12-19-2012 07:48 PM
  3. dcastillo's Avatar
    If the source is designed for high power charging then the cable won't matter...
    Personally, I use one of the retractable cables, any length you want...
    sent from a Nexus, nothing less will do...
    12-19-2012 10:54 PM
  1. short charging cable,can I extend it?
    By paparazzo79 in forum Google Nexus 7 (2012) Accessories
    Last Post: 11-26-2012, 09:42 AM
  2. Longer charging cable?
    By prim8 in forum AT&T Captivate
    Last Post: 08-02-2010, 06:23 PM
  3. Longer Charging cable
    By BoostedGT in forum Motorola Droid X
    Last Post: 07-18-2010, 11:40 AM
  4. USB Charging Cable
    By pkoerber in forum EVO Accessories
    Last Post: 07-02-2010, 10:00 AM
  5. Charging cable question
    By Prospekt in forum Motorola Droid
    Last Post: 01-19-2010, 11:00 AM
