Results 1 to 14 of 14
    Default Cyanogenmod 10.1 update problems
    I flashed cm 10.1 and the latest 4.2 apps I rebooted my phone. As soon as I unlocked my phone a popup window said setup wizard has stopped and it won't go away after pressing ok. The phone is pretty much useless other than the camera, which you can get to from the lock screen. I did a full wipe and tried again, but again the setup wizard stopped working. I had to go back to cm 10.0 because it would not work at all. Anyone else having this issue?
  2. #2
    Default Re: Cyanogenmod 10.1 update problems
    I have the same problem.. for the moment i found a way around it ba accessing the status bar and then using another launcher
  3. #3
    I had the same issue with my GNex. I re-wiped and also wiped the dalvik cache and it worked just fine. CM 10.1 is smooth and fast and seems to be good on battery life. I was on codename android 3.8.0, which is based on JB 4.1.2, but I like cm 10.1 much better.
    Hope that helps you.
  4. #4
    I wiped dalvik but unfortunately no improvement, I'm currently running lovely sans-Gapps but it's still a great inconvenience.
  5. #5
    You aren't attempting to go from 10 to 10.1 are you?? I am not trying to be insulting when I ask, I put 10 on my phone and installed 10.1, and ran into issues. I flashed 10.1 after wiping data, including the dalvik cache, and installing 10.1 and gapps.
    I wish I could offer additional help.
    Merry Christmas!
  6. #6
    I had the same problem yesterday. I ended up flashing my phone three times. What I figured out was that the gapps that I had was the wrong ones. I flashed back to CM 10. Put all my apps back on my phone. Flashed cm10.1 and then downloaded gapps from rom manager and everything worked fine afterwards.
  7. #7
    Comineeyeaha's Avatar
    Posts
    Global Posts
    710 Global Posts
    Carrier
    GNex: CM10. N7: stock
    Yep, gapps is likely the problem. There's a 20121212 gapps out there somewhere, can't remember where I got it.
    Sent from my Nexus 7 using Tapatalk HD
  8. #8
    seanubis's Avatar
    Posts
    Global Posts
    251 Global Posts
    Carrier
    Stock
    Quote Originally Posted by Comineeyeaha View Post
    It's in ROM Manager - currently top of the list in the Google Apps section.
  9. #9
    Hi
    I had the same problem but I don't have usb access to copy the correct gapps version. Is any way to do it from recovery?
    thanks for your help
  10. #10
    how did you flash back to 10?
  11. #11
    ROM manager provides the option to install Google Apps when you flash CM10.1. However when I selected that option I had the same issues. Does ot make sense to flash CM10.1 and then separately install Google Apps via ROM manager (as the 20121212JB is available in Rom Manager)
    Should I wipe the data, cache etc before installing GAPPS?
    thanks for any advice
  12. #12
    my phone just stuck at the unfortunately your setup wizard has just stopped, i kept wiping and wiping and it seems to be pretty useless.....
  13. #13
    gollum18's Avatar
    Posts
    Global Posts
    1,528 Global Posts
    Carrier
    Stock Rooted Mk3
    Quote Originally Posted by Kelvin Khq View Post
    Did you do a full wipe.
    -data
    -dalvik
    -cache
    Sent from my SPH-L710 using Tapatalk 2
  14. #14
    I have wiprewd everything and it is still doing it... My tablet is useless. Wont even boot into recovery
  1. Cyanogenmod 10 update
    By guitarbite747 in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 10-24-2012, 01:05 PM
  2. FROYO 2.2 Update Problems....
    By SlickRick107 in forum Motorola Droid X
    Last Post: 09-22-2010, 09:40 AM
  3. Market & Auto-update problems
    By ethan in forum Motorola Droid
    Last Post: 08-24-2010, 04:04 AM
  4. App Downloads and updates problem
    By petey66 in forum AT&T Captivate
    Last Post: 08-20-2010, 09:14 PM
  5. Facebook update problem
    By peppage in forum Android Apps
    Last Post: 12-31-2009, 12:30 PM
