Phone not charging while plugged in
I have two problems here. The first (which i'm not sure if it's related to the second) is that the phone does not charge when the mini-USB side of the power cord is slightly bend towards the back of the phone. Here is a picture, [Only registered and activated users can see links. Click Here To Register...] or [Only registered and activated users can see links. Click Here To Register...] if that doesn't work, depicting what I am describing, the red F (force) in direction of the green arrow.
The second is that the phone show's "Not Charging" while plugged into the computer or the wall. It's losing power even though the lightning bolt is showing up on both the lock screen and the battery screen. The battery screen says it's "Not Charging" which I believe. Also in the first picture below, it says it's charging too.
and
Re: Phone not charging while plugged in
Hardware problem, call for a replacement. Mines just did basically the same thing.
my phone is not charging...when i plug the phone to the charger,the charger makes sounds annd the light of the charger is gone....but when i tiely hold the wire back wards near the phones ubs opening...the light comes but the screen shows..connect your charger,,,please help out....
Try a different cable. If that doesn't work, then the USB port is probably broken. If you plug the phone into your computer does it have and keep a data connection with the computer?
Strange, my wife's nexus just stopped charging today...
Ironically it charges when the phone is off but does /shows nothing when it is plugged in and on ...
Posted by a Nexus
Posted by a Nexus
I just had the same thing happen to my nexus......
