Long story short, the bottom inch and a half of my galaxy nexus was accidentally dropped in liquid. I immediately pulled it out, pulled the back case + battery out. Phone acted whacky and kept rebooting so I took a friends advice and dunked the thing if rice for several hours and use a low heat on the blow dryer to dry any residual moisture within the device. An hour later the device booted up, no problems!
But then came trouble....Upon charging my device, and pulling the charger out, I noticed the battery indicator was stuck on charging mode. I thought no big deal...a couple hours later the screen would spontaneously come on and when I hit the power button to shut the screen off, it would shut off for about 2 seconds only to come back on saying the device was "charging." The only way I could get the screen to shut off was to plug the charger in and then shut off the screen manually.
This is becoming a bit of a nuisance and I was wondering if someone could point me in the right direction so I know what needs to be replaced internally so I can resolve this issue?
