4 Attachment(s)
Custom Wallpaper Setting (Using Nova)
I have a custom set up I use for my desktop, I got the inspiration online and now cannot find the original author. Anyway, below are pictures posted of my current setup:
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
I made a custom wallpaper that I want aligned with each home screen and matched up, I original made the picture from a template of a screenshot:
The problem I am having is getting it the right size so as I scroll the screen each background section lines up. Does anyone have any ideas on size and placement? I am using nova and can use the "portrait" select for the wallpaper. I first figured I would need to make the entire image (all 3 home screens together) 720 pixels wide, the size of one screen so it would scroll, but this distorts the image once on my phone and sized.
I know this is a little confusing, but if anyone understands and has any other ideas I would appreciate. I have fooled with it a few hours and feel like my mind is missing over something simple and need and outside opinion.
Thanks for any help.
Re: Custom Wallpaper Setting (Using Nova)
so you are trying to make one big wallpaper to scroll evenly with each screen?
if so, dont even bother. Multi picture live wallpaper. allows you to set up images for different screens. and throws in a handful of transitions as well.
Yes, thank you! I will try it out.
3 Attachment(s)
Success! Works great! Just need to refine my image a bit.
MHPSPEED, your setup looks sharp. I like it.
