Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By turdbogls
  • 1 Post By mhpspeed
    mhpspeed's Avatar
    Posts
    Global Posts
    55 Global Posts
    ROM
    STOCK
    Default Custom Wallpaper Setting (Using Nova)
    I have a custom set up I use for my desktop, I got the inspiration online and now cannot find the original author. Anyway, below are pictures posted of my current setup:
    Custom Wallpaper Setting (Using Nova)-uploadfromtaptalk1357915492923.jpgCustom Wallpaper Setting (Using Nova)-uploadfromtaptalk1357915505323.jpgCustom Wallpaper Setting (Using Nova)-uploadfromtaptalk1357915515689.jpg
    I made a custom wallpaper that I want aligned with each home screen and matched up, I original made the picture from a template of a screenshot:
    The problem I am having is getting it the right size so as I scroll the screen each background section lines up. Does anyone have any ideas on size and placement? I am using nova and can use the "portrait" select for the wallpaper. I first figured I would need to make the entire image (all 3 home screens together) 720 pixels wide, the size of one screen so it would scroll, but this distorts the image once on my phone and sized.
    I know this is a little confusing, but if anyone understands and has any other ideas I would appreciate. I have fooled with it a few hours and feel like my mind is missing over something simple and need and outside opinion.
    Thanks for any help.
  2. #2
    turdbogls's Avatar
    Posts
    ROM
    changes all the time
    Default Re: Custom Wallpaper Setting (Using Nova)
    so you are trying to make one big wallpaper to scroll evenly with each screen?
    if so, dont even bother. Multi picture live wallpaper. allows you to set up images for different screens. and throws in a handful of transitions as well.
    You know your rooted when bootloops don't scare you anymore.
    Thanked by:
    mhpspeed likes this.
    mhpspeed's Avatar
    Posts
    Global Posts
    55 Global Posts
    ROM
    STOCK
    Yes, thank you! I will try it out.
    mhpspeed's Avatar
    Posts
    Global Posts
    55 Global Posts
    ROM
    STOCK
    Success! Works great! Just need to refine my image a bit.
    Attached Thumbnails Attached Thumbnails Custom Wallpaper Setting (Using Nova)-uploadfromtaptalk1360341633724.jpg   Custom Wallpaper Setting (Using Nova)-uploadfromtaptalk1360341645822.jpg   Custom Wallpaper Setting (Using Nova)-uploadfromtaptalk1360341657444.jpg
    brianr8011 likes this.
  5. #5
    Quote Originally Posted by mhpspeed View Post
    MHPSPEED, your setup looks sharp. I like it.
    --HTC Droid Eris - HTC Droid Incredible - Motorola Droid X - VZW Galaxy Nexus - Now with more swagger!
    --Nexus7
    Thanked by:
  1. Live wallpaper that uses a video for a background
    By aluminous in forum Android Applications
    Last Post: 12-03-2010, 06:33 PM
  2. Non-custom ringtone setting?
    By momof2inmn in forum HTC EVO 4G
    Last Post: 11-16-2010, 09:05 PM
  3. Custom Wallpaper
    By Dan0384 in forum Motorola Droid X
    Last Post: 07-16-2010, 03:26 PM
  4. custom ringtone setting
    By threepio in forum Verizon Droid Incredible
    Last Post: 06-17-2010, 04:42 PM
  5. Installed Leaked update - wallpaper set issue
    By Wolverines in forum HTC Hero
    Last Post: 05-16-2010, 08:29 PM
