Results 1 to 5 of 5
- 02-17-2013, 08:57 PM
Thread Author #1
Battery drain? Normal?
I use my nexus from time to time and does this seen like normal battery drain for it to be in airplane mode and just Wi-Fi on? It's also a extended battery
Sent from my Galaxy Nexus using Tapatalk 2 - 02-18-2013, 11:50 AM #2
- 02-19-2013, 12:43 AM
Thread Author #3
This is just sitting around all day in airplane mode. Wifi on and it's the Samsung 2100.
Sent from my iPhone 5 using Tapatalk - 02-21-2013, 02:09 AM #4
Re: Battery drain? Normal?
Does Wifi still work in Airplane mode? I thought it didn't.
I get much worse results with Airplane mode.. My battery life is atrocious.. - 02-21-2013, 07:52 PM
Thread Author #5
Yes it does I think I'm going to move to another android device. Put this thing up on eBay.
Normal battery drain % per hour: what are you getting?
By pcguys in forum Samsung Galaxy S3Replies: 28Last Post: 02-25-2013, 08:17 AM -
MT4G Battery drain, higher than normal battery temperature, lag
By blaze420 in forum General Help and How ToReplies: 2Last Post: 08-16-2011, 06:32 AM -
battery draining-- not normal
By bocadave in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 2Last Post: 07-06-2011, 12:07 PM -
Some days battery drains fast, other days normal?!
By hnguyen30 in forum Verizon HTC ThunderboltReplies: 12Last Post: 05-10-2011, 07:16 PM -
Advanced Task Killer Battery drain is this normal?
By cheebahawk1 in forum HTC EVO 4GReplies: 13Last Post: 06-06-2010, 06:54 PM
Reply
