Hi,
I'm wondering if anyone knows a way to disable the popup that comes up when the battery is below 15%? I'm rooted, running stock.
Thanks
Printable View
Hi,
Thanks
Yes that would be nice to know. Not only is it redundant (I can see the red battery), but the constant pop-ups drain it even faster and get in the way. Or even a way to make it only alert at like 4%.
