1. Vance14's Avatar
    I just noticed that the System Update section is entirely missing from my "About Phone" in settings. It was there when I was upgrading from ICS, since I spent a lot of time going there to "Check for Update". But now, even after a couple of reboots, it is just gone. Any thoughts?
    03-19-2013 01:53 PM
  2. trunks527's Avatar
    Are you stock or on a rom? My carbonrom doesn't have it but I've been on 4.2.2 for awhile
    03-19-2013 01:57 PM
  3. Vance14's Avatar
    No, I went back to stock from Bugless Beast when I needed to do a factory reset, haven't even rooted it since then. Very odd. Currently on 4.1.1
    03-19-2013 01:59 PM
  4. trunks527's Avatar
    Do you have the google frameworks disabled? Another user just posted their button was gone because they accidentally disabled the framework services.
    03-19-2013 03:30 PM
  5. Vance14's Avatar
    No, it is enabled. It is all baffling.
    03-19-2013 03:43 PM
  1. Replies: 0
    Last Post: 12-28-2012, 05:23 PM
  2. Replies: 0
    Last Post: 04-29-2011, 10:46 PM
  3. Don't you find it odd that some of the biggest online store still...
    By Visual360 in forum ASUS EeePad Transformer
    Last Post: 04-26-2011, 01:38 AM
  4. Replies: 7
    Last Post: 12-12-2010, 05:35 PM
  5. Is it possible that the bugless beast is actually... BUGLESS?
    By PRNmeds in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-22-2010, 10:00 PM
