Results 1 to 4 of 4
    Default What does it mean when I enable wireless & wifi (or 4gLTE)?
    When I am at home I usually connect via wifi to my access point and turn off Mobile data (to save my monthly Verizon wireless data-usage). But what I wanted to know is how the data gets distributed between the AP & mobile when I do have mobile data enabled.
    Does the phone first try to use 4G then the AP? Or if there some load balancing going between the two?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: What does it mean when I enable wireless & wifi (or 4gLTE)?
    Depending on the phone and the carrier, it will use one or the other. (It's better for the carrier, of course, if you use 4G whenever you can.) There's no balancing or dual connecting going on - it's one or the other. Just turn data off when you're home. Data ON-OFF makes it easy. It's a widget that puts an icon on your home screen to turn data on and off and let you see which it is (grayed out if it's off).
    Quote Originally Posted by Rukbat View Post
    Say thanks, I just read also that connecting the mobile drains your battery so connecting to my wireless at home should help make my battery charge last longer. Great widget!
  4. #4
    The phone SHOULD bypass the cellular data connection if you're on a WiFi network. It USED to be that the cellular data symbol (4G or LTE in your case) would disappear when you were on a WiFi connection, the newer versions of Android have just greyed them out instead, possibly causing your confusion.
  1. 4.3 update on its way for gt-n8013.
    By thurmanbr549 in forum Samsung Galaxy Note 10.1
    Last Post: 02-19-2014, 08:14 AM
  2. Samsung Galaxy Mega GT-l9152 Straight Talk no internet without Wifi
    By rayinme in forum General Help and How To
    Last Post: 02-11-2014, 08:31 PM
  3. I don't get it about tablet pricing....
    By JnEricsonx in forum General News & Discussion
    Last Post: 12-30-2013, 08:35 AM
  4. Voice mail app does not work right
    By edsmega in forum Verizon Samsung Galaxy S4
    Last Post: 12-29-2013, 05:04 PM
  5. Hangouts or SMS
    By NickA in forum Moto X
    Last Post: 12-29-2013, 02:13 PM
B
