Results 1 to 6 of 6
    ulnek's Avatar
    Posts
    Global Posts
    757 Global Posts
    Default Can AT&T Use the Verizon Galaxy Nexus (Toro) on their Network?
    my dad is trying to get an entry level smartphone so i thought i'd give him my galaxy nexus. he's on at&t though. just wondering if it would work. also, he has a regular size sim card. can he just go to an at&t store and ask for a smaller sim card to be able to fit in the galaxy nexus? thanks for any help.
  2. #2
    Aquila's Avatar
    Gonfaloniere
    Posts
    Global Posts
    13,605 Global Posts
    Carrier
    Assassin 'Droid
    Default re: Can AT&T Use the Verizon Galaxy Nexus (Toro) on their Network?
    I do not think this is possible for this specific phone because of the bands that each device has access to via hardware options. It may be possible to hack the LTE connectivity, but as far as I know the Toro (Verizon version) is only set up to use CDMA/EV-DO and Band 13 LTE while the Maguro (GSM unlocked version) only has GSM/HSPA/HSPA+21 hardware and no LTE option on board. Essentially, it wouldn't be able to get calls or connect to mobile data.
  3. #3
    Default Re: Can AT&T Use the Verizon Galaxy Nexus (Toro) on their Network?
    My understanding is that the Verizon gnex didn't contain gsm radios, so no it can't be used on AT&T. No mention of gsm in the fcc filing.
    http://www.engadget.com/2011/11/15/s...h-verizon-lte/
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    Aquila likes this.
  4. #4
    GUHoya94's Avatar
    Posts
    Global Posts
    66 Global Posts
    No it will not work on AT & T. However it would work on Sprint. Different Radios in it. Hope that helps.
  5. #5
    Quote Originally Posted by GUHoya94 View Post
    The radios support it however Sprint requires phones on their network to be in their database, otherwise Sprint would refuse to activate it.
    Same with Verizon, they will not allow you to activate a Sprint phone on their network.
    ulnek's Avatar
    Posts
    Global Posts
    757 Global Posts
    ah well. worth a shot. thanks all for the info.
  1. Is the Play Store broken tonight?
    By Sandman333 in forum Motorola Droid MAXX
    Last Post: 04-14-2015, 11:48 PM
  2. Verizon Edge users
    By 4m0wagen in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-25-2014, 04:44 PM
  3. Cannot update MTP drivers on N7- device recognized but cannot access storage
    By boydcc18 in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-03-2014, 01:46 PM
  4. How Can i root my verizon htc one 4.3?
    By jayramos19 in forum General Help and How To
    Last Post: 03-28-2014, 07:55 PM
